Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 03-12-2006, 04:27 PM
SVXfan01 SVXfan01 is offline
Send a message via MSN to SVXfan01 Send a message via Yahoo to SVXfan01
Switch for the 1.4 Chip
Question, do you need to install a switch for the 87 octane chip or can you just install the chip and be done with it?
Old 03-12-2006, 04:36 PM
immortal_suby's Avatar
Thread Killah
if you want to use the 87 octane code you need to install a switch.
if you don't want to use teh 87 octane code you can just install the chip and be done with it.
Locker Link
2015 BRZ Limited 6MT
Old 03-12-2006, 05:12 PM
SomethingElse's Avatar
word words wording
chip swap
has anyone tried to put the swap the two chips? this way you would defualt on 87 and switch for premium?
Eric
Old 03-12-2006, 05:34 PM
longassname's Avatar
Just some dude.
Significant Technical Input
It doesn't work that way. If you want to be on the 87 octane code all the time you need to install the wire. You can leave the switch out and just connect straight to the power source if you don't want to be able to switch back to the premium version. Switches are cheap though. You might as well use one and just tuck it up under the dash so you don't have to worry about mounting it.
Old 03-13-2006, 11:37 AM
Earthworm's Avatar
Meow!
One place I've installed a switch is in the coin holder. I got the switch from a dead ATX power supply (the master power switch) and mounted it upside down in the top of the coin holder. Very inconspicuous and you can still put coins in there.
Old 03-13-2006, 11:16 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
i placed my switch beside the shifter.
since there was a hole there from the previous owner's alarm LED light
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
