Old 05-12-2005, 08:27 PM
chitownsvx chitownsvx is offline
My differential frys when I use spare tire
Everytime I use a different size tire on my svx rear my differential starts making noise, please tell me what this is. ANYBODY
Old 05-12-2005, 10:47 PM
deruvian
You cannot use odd/different tire sizes on ANY AWD vehicle. All tires must be matching in size.
The only way to work around this is to insert the FWD fuse. It will put the center differential into "FWD mode", effectively turning off the rear end and transferring all the power to the front end. It is in the engine bay fuse box, 10 amp.
Old 05-12-2005, 11:38 PM
even with the fwd fuse in, it will still burn up the rear diff as it is limited slip.
Old 05-13-2005, 07:14 AM
dcarrb dcarrb is offline
...which means you have to use a spare with the same outer diameter as the other tires. Like, the one that came with the car.
dcb
Old 05-13-2005, 02:35 PM
That's the one I use
I only have the one spare that came with the car but once I put it on it fried the differential. It was the only time I used it. But I do have 18's on the car but with low profile tires it's almost the same in diameter.
Old 05-13-2005, 02:43 PM
The thing is, all four corners have to be pretty much exactly the same, under all circumstances. And you should never use a "space-saver" spare for any longer than absolutely necessary.
dcb
Old 05-13-2005, 07:14 PM
THAWA
You have to be within 1/4" difference in the circumference. So unless you have 195/45-18's, 175/50-18's, or 145/60-18's you're always going to do damage to your entire drivetrain whenever you use the stock spare. Either get a spare in the right size, or get regular tires in the right size.
Old 05-14-2005, 05:24 PM
svx_commuter's Avatar
I have the four stock size tires and the bologna spare tire. I have driven 160 miles at 50 mph with the spare and had no problem from the rear diff. This has happene twice now
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-15-2005, 11:51 AM
jb21585's Avatar
jb21585 jb21585 is offline
Any time you use a spare, even if you have a blown rear tire, the spare ALWAYS goes on the front of the car. Read the Handbook
1995 Claret SVX LS-i
1985 Toyota Tercel SR5 4wd wagon
Old 05-16-2005, 07:31 AM
That's surprising. I figured the opposite. Seems you'd want your best rubber up front, especially with only the front wheels doing the work.
dcb
Old 05-16-2005, 11:57 AM
dcb
Front diff= open
read diff= limited slip
Still should only drive what is absolutely needed on a spare
Old 05-16-2005, 02:41 PM
Earthworm's Avatar
Meow!
Originally Posted by tomssvx
Front diff= open
I agree
I will add that I wouldn't drive any more than 30mph and no more than 30 miles on a spare. (Same as towing instructions)
Any difference in circumference on ANY of the tires will cause unnecessary wear on the AWD. For our cars though I would think the smaller tire on the back would be safer on the AWD but harder on the rear diff since the TCU would think the rear tires are spinning faster than the fronts and not send any power to them.
Old 05-16-2005, 03:04 PM
TCamusJr TCamusJr is offline
i've been riding on the spare 'donut' since April 30...500+ miles thus far...
luckily my new wheels will be here tomorrow.
Old 05-17-2005, 07:05 AM
(This is just an observation, not intended as fuel for debate.)
My owner's manual ('92) makes no mention of limiting the use of a space-saver spare to one axle or another, nor of inserting the FWD fuse while the spare is in use. Curiously, though, it does read:
"This tire has a smaller diameter, so road clearance is less. When driving across rough terrain, always be sure there is sufficient clearance."
Smaller diameter? That's a surprise. It continues with cautionary copy about keeping speed below 50 mph and limiting the spare to temporary use.
Was this changed in later models?
dcb
Old 05-17-2005, 08:29 AM
I am not sure what the handbook says to do. It only makes logical sense that you would keep the spare on non-powered wheels. For FWD keep it on the rear axle and for RWD keep it on the front axle. For an AWD car like ours it can only make sense to keep it on the axle with and open differentials as to not wear out the limited slip clutches in the rear differential. Although the front diff is an open differential it will cause damage if high speeds are obtained or long distances driven. It would be like driving with 1 wheel and it would fuse the spider gears in the front diff to the cross pin. So it makes perfect sense for an AWD SVX to keep the spare on the front. Only drive it the needed distance to get a new tire. All other options should be obsolete as they would be detrimental to the vehicle's driveline.
