Old 07-31-2003, 11:12 PM
deruvian
1994 Svx Le?
I've been looking at buying a very particular SVX, and the seller advertised it as a 1994 L series. When I Carfax'd it, it was reported as a 1994 LE. I have heard of the LE series before, but never looked into the specs. Does anyone know the technical nature of the LE and how it differs from the L/LS series?
Thanks!
Old 07-31-2003, 11:20 PM
nordique14's Avatar
nordique14 nordique14 is offline
Who watches the watchmen?
Check out this link for details on SVX models:
http://www.cars101.com/subaru_svx.html
It will tell you what model it is by the VIN number. Also lists all the standard equipment and options for particular model. Note that the 1994 models (other than LSi) are FWD. If you go to Reno/Tahoe a lot during the winter, you might want to look for an AWD model.
Cheers,
Old 08-01-2003, 09:47 AM
mbtoloczko's Avatar
sans SVX
Cheers,
The SVX specs that Joe Spitz posted on cars101 is does not necessarily represent the actual end products. I know of several 1995 L models, including my own, that are AWD, have a CD player, ABS, have carpeted floor mats, and have a rear spoiler, all of which were not standard features on that model SVX.
The carfax report of an LE is probably just a typo. Or maybe they confused it with a Toyota Camry. :-)
Mychailo
Visit my locker
Old 08-01-2003, 10:13 AM
deruvian
mbtoloczko, on the 1995 L series, AWD was included in an optional package...
Anyways, after thoroughly reading through Joe Spitz's page ( http://www.cars101.com/subaru_svx.html ), this is what I found out:
The 1994 L series has the following characters in the VIN#, starting at the fifth character from the left: X33.
The 1994 LS series has the following characters in the VIN#, starting at the fifth character form the left: X34.
The 1994 LSi series has the following characters in the VIN#, starting at the fifth character from the left: X35.
The VIN# of the SVX I am looking at is: JF1CX3232RK****72. And interestingly enough, the sequence starting at the fifth character from the left is: X32. This doesn't fit under the L, LS, or LSi VIN# specs. Apparently, it is some different model, most likely being an LE (cause that's what CARFAX tells me!).
Anybody have any other info? I'm way curious!
Thanks!
Old 08-01-2003, 11:33 AM
mbtoloczko's Avatar
sans SVX
I understand that AWD was an optional package. That's why I said those items were not *standard* features.
Anyhow, I guess it is an LE.
Mychailo
Visit my locker
Old 08-01-2003, 06:55 PM
immortal_suby's Avatar
Thread Killah
maybe a typo by the seller?
Locker Link
2015 BRZ Limited 6MT
Old 08-02-2003, 09:20 AM
Kerven Subaru
a 94 LE is a FWD model with one airbag and power seatbelts. The L is a FWD model with two airbags and manual seatbelts.
Otherwise they are are same.
Mike
Kerven Subaru
