Old 07-19-2003, 10:08 PM
MAD4SVX
Signal Lights
Hi Guys,
My signal lights have stopped working. Can anybody help me?
The left, right and hazard lights stopped working one day. I thought it might be the flasher unit under the stearing wheel so I bought a new one but it still does not work.
The lamps do not come on at all and there is no clicking noise. Can any body tell me where the fuses are? I tried the ones in the kick panel but they were all ok. There is 12v going to the flasher unit so it may not be fuses.
Are ther additional relays? Where are they ?etc
Any help woild be appriciated - I have the Chilton manual but it's not very good - the signal lights are not even on the body electrial diagram!
Thanks
Mark
PS The subscription to the spell check has expired.
Old 07-27-2003, 06:50 PM
MAD4SVX
Additional:
I have also found that my back lights are not working - the front ones are fine.
since my last post I've
-checked evry bulb I can find - all good
-checked each bulb's earth - all good
-checked evey fuse I can find including behind the dash and the ones in the engine compartment - all good
Any body got any idea what can stop my back lights and signal lamps from working?
Thanks
MAD4SVX
Old 07-27-2003, 06:57 PM
IwantaSVX IwantaSVX is offline
Send a message via ICQ to IwantaSVX Send a message via AIM to IwantaSVX
I had the same problem when I removed my under dash panel (suede) and did not have the switches connected. There is a parking light switch. It may be bad.
Old 07-28-2003, 11:44 PM
MAD4SVX
I found the problem!!! Broken wire. The plactic was intact but the wire inside was broken.
Cheers
MAD4SVX
