Go Back   The Subaru SVX World Network > SVX Main Forums > Upcoming Meets
Old 10-24-2006, 04:19 PM
Possible Dyno Meet outside of Philly
Mikecg and I are in need of hitting the dyno with our cars... May just want to make a meet out of this to save money and to see some people we haven't seen in a while. I need an exact amount of cars that will be there for sure so I can get a price... Let me know if u want in... The date right now is for Thurs Nov 16th.
P.S. here is the link for the shop...AWD Dyno
Old 10-24-2006, 04:24 PM
Speedklix's Avatar
Locker Link Solution
YAY for numbers!
There is a 90% chance I can't make it down there for that, but it would be cool to see the stage 3 get it's numbers.
I'm also curious to see what my SVX makes... hmm, do I need a break??
It would be a great chance to meet some of the Jersey crew too!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-24-2006, 04:26 PM
Here is another one. Xotic has a dynjet, which is usually off and this one has a Mustang Dyno, which are known to be very accurate
http://www.awe-tuning.com/pages/info/map.cfm
Old 10-25-2006, 11:45 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
My vote is for Xotic, as it's around 50 miles closer to me Using the DynoJet will also build on the current DynoJet-based SVX database!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-25-2006, 12:58 PM
mikecg's Avatar
mikecg mikecg is offline
Tom, I'd recommend 4 pulls at least for your car and mine. I'll have 3 sets of software with me. 2 of them I want to make sure we both try out. I figure 2 pulls per version for a total of 4. If your not doing anything to the car there really isnt any need for more then 3 pulls for a car. If you want to try the software your currently running, you may want an extra pull or two for your car.
Now I need to figure ot what the deal is with my car. I think I may have a vacuum issue. I'm still getting the check engine light, and my boost gauge is reading low. Either I have a boost leak, or more likely I have T'd off the vacuum line on the manifold too many times. The gauge is barely getting above 5lbs. I'm also using a rubber vacuum hose on the gauge which can cause a slight discrepance in the reading.
Old 10-25-2006, 03:31 PM
SVXRide's Avatar
Mike,
Given how the ECU is mounted under the dash and how it "learns", I'm not sure if this approach is going to work (i.e., you probably won't have enough time). Factor in the time it takes to get the cars ready for runs and two hours will go by real fast!
Might be a good idea to just have you run one software version and Tom run another and then just compare hp/tq curves - given that Tom's higher level of boost should just move the curves up (everything else being equal)
Just my 2 cents....
-Bill
Old 10-25-2006, 08:37 PM
Mike, I would recomend you use a dab of RTV on all of you vaccum lines to be sure they are leak free.
Bill, I think changing an ECU is cake and if we just leave them dangle while the pull is in progress we should be fine. I wanna see if we can round up some ECU's and maybe Lan can send us a couple extra boards so we can just swap seperate ECUs and not just the software
Old 10-25-2006, 11:05 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
I'm in... Crazy how I just happen to be on the eastcoast for this...
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 10-25-2006, 11:36 PM
Oh yeah... I forgot about this joker showing up
Old 10-26-2006, 05:31 AM
mikecg's Avatar
After demo'ing all the software I have recently. I can switch out the software in about 2 minutes. Especially if we take the exspansion board from the car that isnt on the dyno and have it ready with the second set of software. Right now I have 2 nuts holding by ECU in and the cover is still removed. I figure when we have a final software figured out I'll close it up.
Old 10-26-2006, 08:44 AM
well before we get the cars up, we can just take the ECU down and take the cover off... This way we can just chnage out the chips... That was LAN's suggestion
Tom,
Old 10-26-2006, 10:41 AM
gest24's Avatar
#1 6MT In Cali
You guys can always pull the ECU out of the Pearl that I'll be driving so you can have 2 standbys.
RIP
84 VW Scirocco
02 WRX
Old 10-30-2006, 09:26 AM
Alright, I am going to make the cut-off date the in 2 days... thats right... The 1st of November, you need to tell me whether you are comming and whether you are running the car on the dyno, I need to get thm a set amount of #'s and reserve the time
Old 10-30-2006, 09:31 AM
mikecg's Avatar
Sign up List:
1)TomsSVX
2)MikeCG
Old 10-30-2006, 12:28 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
PM or call Kevin Thomas (Myxalplyx). He might be up for re-dynoing my former SVX or one of his XT6's...
2006 Steel Gray WRX TR (sold)
