Old 03-15-2006, 02:26 PM
supertole's Avatar
supertole supertole is offline
AWD
Transmission filter kit
Hello,
Does anyone have changed the transmission filter? I've seen there are tansmission filters and transmission filters kits, what is the difference?
Does anyone know an european online store (webpage) where I could by the SVX's transmission filter/kit?
Another question: does the SVX have particles fiter?
Thanks!
Old 03-15-2006, 02:29 PM
There are 2 filters
- there is a screen filter located in the transmission oil pan
- there is a particle filter located at the bottom of the radiator. This filter is approximately the same size as the fuel filter.
Old 03-15-2006, 02:49 PM
supertole's Avatar
AWD
Wich filter is the filter of the photo?
I've found this filter in many U.S. online stores but not the radiator one you said.
P.D.: when i said particles filter I referred to "pollen filter".
To have the things clearly can anyone post ALL the filters the SVX has(Air filter, transmission filter or filters, oil filter...)
thanks!
Old 03-15-2006, 02:54 PM
That one is inside the transmission. You can see it once you remove the transmission oil pan.
Old 03-17-2006, 05:29 PM
supertole's Avatar
AWD
upppppppppppppp
Old 03-18-2006, 05:45 PM
Arthur-UK's Avatar
Arthur-UK Arthur-UK is offline
http://en.wikipedia.org/wiki/Subaru_Alcyone_SVX
"The early automatic transmission failures were caused by a screen installed at the entrance of the transmission cooler. Normal wear debris would build up at the screen and reduce/stop automatic transmission fluid flow and thus kill the transmission. Subaru later corrected this by removing the screen and installing a proper filter in the automatic transmission fluid circuit."
Old 03-20-2006, 11:27 AM
The screen that was removed was in the radiator. The internal transmission screen filter should never be removed (unless you want to immediately kill your tranny).
Old 03-20-2006, 11:50 AM
Arthur-UK's Avatar
Inside the radiator ? Sound unlikely, the heat exchanger is usually just a length of steel pipe sitting in one of the headers. It describes it as if was in the transmission oil pan.
Old 03-20-2006, 04:17 PM
It mentions the entrance of the transmission cooler. This cooler is in the radiator. Only the 92's had the screen. The newer radiators do not have this screen.
Old 03-20-2006, 10:53 PM
Yes, there was a screen that plugged up in the radiator on the 92.
Old 03-21-2006, 01:15 PM
supertole's Avatar
AWD
So a 1994 SVX only have one transmission filter as shown in picture?
http://www.subaru-svx.net/forum/atta...7&d=1142459258
Old 03-21-2006, 01:33 PM
supertole's Avatar
AWD
Does my car have this filter?
What is the role of this filter?
I found the picture at
http://www.svxworldnetwork.org/html/index.html
How to &faqs/ATF Filters
Thanks!
Old 03-21-2006, 02:21 PM
Yours should have that filter. It's located at the bottom of the radiator on the left hand side.
Old 03-21-2006, 02:53 PM
supertole's Avatar
AWD
And which filter is it? Transmission Oil Filter? Engine Oil Filter?
October 1994 SVX
Old 03-21-2006, 03:15 PM
Transmission. It filters particles too small to be caught by the internal transmission screen filter.
