Engine rebuild advice
Is there Anything that can be done with the SVX engine besides a standard "OEM parts" rebuild. Any cams, or fancy valve porting? Anything??
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
Not unless you want to do it yourself.
are thinking of doing anything on your old engine????
you first need to find a good source for reliable yet inexpensive bearing sets. Not to mention ring sets also. The OEM parts will cost you almost more than a Stage 3kit
Tom |
Thanks guys.. I just hate going through the time of a rebuild without enhancing the performance some. sigh...
I have no idea what I'm going to do with the engine out of the 92. I bought the car with a known and very aggravating click in either a lifter or valve on the driver's side. I dread stopping at a red light.
You can always contact Paeco or Crower for better aftermarket engine components. It is a matter of how much you want to pay for the rebuild. You can ask for Forged Pistons and Titanium Cams... Deves Rings...Oooops, i said too much...
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. Last edited by SilverSpear; 10-13-2005 at 02:23 PM. |
I never heard your 94 engine run..... But if it was running fine before you started having electrical problems I would mess with it. And instead the 92 engine will be a better prospect to rebuild since is not running good. I also notice that valve and plus is not running smooth. JUST A THOUGHT!!!!!
Would you believe it even shifts like silk after installing new O2 sensors? You'd never think the O2 sensors would make a difference in shifting, but that was the only thing I had changed. The car just "flows" into the next gear now. Ultra smooth. Incredible. The difference was outrageously noticeable. But.... That click is still there. I tried washing it out, and soaking it out.... but still....click,click,click. I even stared at the intake manifold! That didnt help either! The 94 had a barely audible click to it too. You had to listen for it, but still.... take care of it prior to swapping out. Rebuilding the engine in the 92 would put the car out of commission, and that engine has 157k on it. The 94 has less than 80k, and the car would only be out of commission for a weekend as I swapped engines.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) Last edited by Electrophil; 10-12-2005 at 11:38 AM. |
What was the price for the O2 sensor and where. Know the higher mile engine I believe will be the best prospect to be rebuild. And what i ment is to live the 92 for the project. Swap the 94 just the way it is and the the 92 put it aside to be rebuild. I know it will take a long time to try to find the right parts to maybe reduce compression and maybe turbo or supercharge it safely. I want to do that but right now no money and no spare engine to mess with.....
O, and how mutch will you sell me the extra set of manual for the svx.????
1 miiiiiillllliiiiiooooonnnnn dollahs!
Ho man,,, I guess I have to work overtime!!!!!!! jajajajajajaj
So what was the price of the O2 sensor??? |
1992 Pearl White SVX LS-L 1991 "Red Baron" Grand Prix GTP 5spd 2002 Chevy TrailBlazer LT |
