Pro Detailer
I'm a pro detailer and have been for a few years. If you have any questions on how to get your SVX to look it's best then let me know.
Welcome to the site. Do you own a SVX? We need a good detailer around here. I am not a pro, but can hold my own when it comes to a good shine and detail, but still learning a lot about products and trying them all.
any tips for cleaning salt stains out of the carpets?
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
How about cleaning the interion ceiling and visors without damaging the adhesive or foam padding?
show up at Reading this year and you'll clean up (pun intended )
-Bill
Spray some all purpose cleaner on a rag and gently rub the stained area. Repeat with water. Folex is a good all purpose cleaner and can be found at target of home depot. Same process for cleaning the suede interior. Last edited by joburnet; 03-07-2007 at 09:00 PM. |
Darknessofdeath - I would suggest to shampoo carpets. If you don't have an extractor here's how you do it yourself for cheap with a wet/dry vac.
First vacuum the carpets very well. Next, spray the carpets with a cleaner, I've used Folex which can be found at target or Home Depot. It works very well. Let the cleaner soak in for 4-5 mins and brush the carpets with a nylon brush, you can pick them up for $2 almost anywhere. The point of this step is to actually remove the stain. Pour some warm-hot water on the carpets to soak them. Then vacuum up the water with the wet/dry vac and get the carpets as dry as possible. If there is still a stain then repeat. Then let the carpets dry, keep the windows cracked a little and leave the car in the sun. It's best to do this on a warm day, the carpets should be dry in a couple hours. If it's a cold day then it could take a long time to dry and mold/mildew could start after a few days. |
In a spray bottle, mix up a solution of 1/2 warm water and 1/2 white vinegar. Spray the stained area with the solution. Press a dry terrycloth towel over the wet area. Remove the towel when it's soaked. Repeat until the stains are gone. But there is a commercial product called Salt-X which is wonderful. I know boat owners who charter their boat (with carpeted decking) to scuba divers and their gear. They use this stuff on a regular basis. Local Distributor: K.C. Trading Ltd. 3665 Jeff Davis Hwy Suite 103 Stafford, VA 22554 Phone: 540-720-8400 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-07-2007 at 09:11 PM. |
Any advice on cleaning the engine area?
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place. |
First of all you have to be carefull with getting water in the engine bay so do this at your own risk. Having said that I've cleaned 100's of engines without any problems. It's pretty simple: Spray the engine bay with a degreaser such as simple green, any decent degreaser will be fine. If you use simple green dilute it at least 4:1, don't use it straight. Make sure to get everything. Spray the engine bay with a hose. I would not use a pressure washer here. This will get out a lot of the dirt and grease very quickly. Now spray individual areas with the degreaser and clean them with a rag and rinse with the hose when your done. That's the process for cleaning, if you want it to look nice spray the entire engine bay with a water based dressing such as armor all. DO NOT use a solvent based dressing, most tire dressings are solvent based. Note: If cleaning an engine with a sound dampener on the underside of the hood make sure not to get it wet. If it gets wet it can fall apart on you. |
Haha... it's been a while but I wanna revive this.
I want to eventually clean the engine bay of my SVX as well, and hopefully with a more effective method than the one I used for my old Legacy (toothbrush, sponge, washcloth, tons of water for cleaning oil-stained cleaning tools). So I had some questions. Could you possibly go into more detail here? I'm totally new to [proper] engine bay cleaning, so when you say "use degreaser on everything" do you really mean everything? Aren't there things that should be covered up, and if so with what? Then the hose part... I heard this is a really bad idea (you said yourself, using water = bad idea), so again... things that need to be covered? With what? Where should be soaked or sprayed, and where should not? Thanks. |
When I clean my engine bay, I cover the alternator with a plastic bag and use degreasser on everything else. Then I use a weak pressure washer with hot water and spray it down. That does a great job. After that, I clean hoses and the other stuff with Mothers - Back to Black and wipe down the plastic parts and spot clean what needs it. Good luck with yours.
It is recommended that you cover anything electrical, alternator and stuff like that. Having said that I've cleaned 100's of engines without covering anything and never had a problem, that's the way pretty much all detailing shops do it. I would suggest you spray anything you want clean with degreaser and rinse with water...so basically everything. |
I know people who don't cover the alternator and don't have problems, but I cover mine with a plastic bag because I don't like to spray it directly with a pressure washer. It still get a little wet, but that way I don't spray it too much. I have never had problems by doing it that way.
