Old 02-25-2010, 05:09 PM
viking64 viking64 is offline
Alternator workings
I have a few questions that I'm sure someone here can easily answer.
With our alternator - if the engine does not run at set speed, how does the volts and output get controlled?
- as our alt is rated at 100 amps - does it make 100 amps regardless or just enough to run the car + accessories - and what typically would be the load used to say, run the engine with A/C on and lights?
and finally - does the alt place much of a load on the engine, like x hp to make x amps or is it a case of it's just there and it just works
just curious
Old 02-25-2010, 05:31 PM
Re: Alternator workings
just curious
The alternator incorporates a voltage regulator. The lower the detected battery voltage the greater the adjusted alternator output in amps.
This also means that with any increase the connected load, the output current will be adjusted.
The alternator does indeed place a parasitic load on the engine, and this will vary in accordance with the output, which in turn will depend on the electrical load. Annoying others at the traffic lights with a boom box, therefore costs you.
Old 02-25-2010, 09:29 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Building on that, most recent cars, I think including the SVX, also have the field control directed by the ECU which also adjusts alternator output for other factors, such as incoming air temp or engine load.
