Honest Opionions Requested
Okay... here's where I'm at. My car has always pulled right a little, so when I noticed a place that does alignment checks, I had 'em take a look. They got it up on the lift, and like all Californians () they were afraid of the rust. But they did let me look all over the car while it was up there, and I snapped some photos of the rear with my phone. They also showed me a little something up front which was distressing. So here it is, here's everything I know about my car. I want to know if it's worth saving, or even if it's possible to save it.
First, pics of the rear. Rust, rust, everywhere... Rust so bad that it ate holes into the brake rotor guide. And then... -Most any part under the car is rusted -Brake rotors need replacing (my own fault for not doing them when I did the calipers and pads) -Engine Mounts are shot (front-left is literally split on top, front-right is very loose) -Engine leaks oil from somewhere inside timing covers (probably cam caps) -Car pulls right (probably a combination of factors) Aside from that, nothing else. The overheating doesn't happen anymore. So...verdict? Should I bother to spend any more money on this thing, or should I just get rid of it? |
Some down time for disassembly, a sand blaster, and some good paint will go a long way to help preserve your svx
Honestly, the rust you have on the components looks to be just surface rust. The backing plates could use changed, just to keep water out of the e-brake. Rust usually isn't a problem, until it starts to rot the metal of the body itself. Even then, until it starts to eat the suspension mounts, it's repairable.
Here's an example of rust that's repairable: Yes, it's structural, but with a proper repair, it's not terminal. This is terminal cancer: Note that it's completly rusted through where the suspension attaches. While the rust you have looks bad, it's not unsafe. As for the rest of your woes, they are cause for concern, but with a one problem at a time approach, they're all fairly simple fixes. My 2bits on it pulling: Have the control arm, and strut bushings inspected.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. Last edited by crazyhorse; 04-19-2008 at 04:06 PM. |
Pfft. That's nothing. I've seen far worse rust. What you've got is "age rust." Surface rust, nothing more.
Ditto them. My rust kicks your rusts' butt any day...
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
I agree, as I was trying to find something of any significance. Fix the car as you know where you will be starting and finishing. Much better than another dive into the wilderness.
Cars here in Iowa have FAR worse rust than anything like what you have on yours,and they run for years and years.
That's really just surface rust that really isn't bothering anything. Sure it looks tacky and you CAN clean it up, but the car is not going to fall apart anytime soon if you do nothing about it.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Here's another example of bad rust. This is the frame of a 1997 Geo Metro. You can't quite see it there, but that crack is all the way through the frame. That car went to the junkyard.
$35,000 later . . . |
Cool, man, that is absolutely cool. Those cars redefined the spirit of motoring for fun in their day. Of course it was worth restoring. Beautiful. Joe
