Old 08-22-2017, 05:47 PM
Huskymaniac's Avatar
Uses the ignore feature
Small Car Headlight Kit
What is the impact of not putting in the spacer for the high beam bulb? I would think the spacer causes the beam to spread faster. Is the spacer supposed to make up for the lack of the light spreading elements in the original lenses?
Tony
Old 08-24-2017, 09:42 AM
SVX n00b
Re: Small Car Headlight Kit
Throw away that garbage headlamp kit and do a proper HID or LED retrofit.
Old 08-31-2017, 10:07 AM
Austin Austin is offline
Well that was helpful.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
Old 08-31-2017, 01:06 PM
Indeed. I thought the small car kit was more of an appearance thing rather than improved lighting. I like the look.
Old 09-01-2017, 08:32 AM
SVX n00b
The small car kit IS just for appearance, and will actually reduce night vision by removing the Fresnel lens in the headlamp that properly distributes light on the road.
IF you perform the modification, the only real way to regain the lost focus would be to retrofit the lamp behind the now clear lens.
Old 09-01-2017, 08:38 PM
92 SVX 92 SVX is offline
That may be for the Brights, and possibly fog lights, but the oem Projector was already projecting through clear lens, so low beam should not have any reduction in visibility.
