Anyone Familiar with the DEH-P7200
Anyone out there familiar with the Panasonic DEH-P7200 stereo or its ilk? I ask because I have a slight issue.
This fits in this forum because (a) I can't find the answer anywhere else and (b) because it's installed in my SVX... therefore it's NOT EXACTLY SVX related... but sorta. Anyway... the question is; I recently disconnected the battery while replacing spark plugs on my baby... helps to do that while removing it. Anyway, since I reconnected it all now the display randomly "flashes". Basically it switches to a "negative" display mode where black is white, white is black and so forth. After a random time it switches back again. It's doing this constantly... It wouldn't be so bad except that it does it when the display is in "clock" mode as well (stereo off)... since this means most of the display suddenly becomes "white" it can be extremely distracting when driving at night. When the stereo's on it's less noticeable but still irritating. Anyone out there tell me WHY it's doing this? I can't find anything in the manuals about this particular problem and can't find any info on the Internet about it either. Help? |
Oh, now that is weird...
Is it a security mode?
It may think it's been stolen.
Your radio wasn't turned on when you disconnected the battery, was it? Some electrical devices don't like to have power interrupted while they are on.
Dave |
It is either in Demo mode or Security mode. (I can't remember which) Pour through the manual and you'll find the fix. I know, my pioneer did that once upon a time and I was able to fix it. Someone stole it a few months later...I miss that stereo. And that amp, and the MTX subs. I'm gonna cry....
'95 Subaru SVX L-AWD 88K miles. |
Sorry for the reminder, Nate!
Yeah, I suspected that it's in security mode... however I'll be darned if I can find a reference to resetting that in the manual. <sigh> Guess that means some closer reading later tonight. |
Try this...
From an F150 msg board:
post: "My question is why afer a short amount of time the background on the display goes from dark to Bright white and then back to black, kind of in a continual cycle? That is the only thing that bothers me and at night it is down right annoying! Can I change that or not?" reply: "The Unit is in the "Demo Mode" actually reverse demo. With the key in the acc posistion and the unit off press and hold the #5 button on the preset selects on the bottom of the unit until you hear a beep. This will cancel the demo mode." See if it works. This jives with what I remember doing. Fingers crossed...
PhatWeasel has it right...one thing to keep in mind is that the DEH-P7200 is a Pioneer unit
I would attach the manual, but why waste the space here, it's available at Pioneer. Here's the applicable text cut & pasted from the online Adobe PDF file. About the Demo Mode This product features two demonstration modes. One is the Reverse Demo mode, the other is the Feature Demo mode. Reverse Demo If you do not perform an operation within about 30 seconds, screen indications start to reverse, and then continue reversing every 10 seconds. Pressing button 5 when power to this product is switched OFF while the ignition switch is set to ACC or ON cancels the Reverse Demo mode. Pressing button 5 again to start the Reverse Mode. Feature Demo The Feature Demo automatically starts when power to this product is switched OFF while the ignition switch is set to ACC or ON. Pressing button 6 during Feature Demo operation cancels the Feature Demo mode. Pressing button 6 again to start the Feature Mode. Remember that if the Feature Demo continues operating when the car engine is switched OFF, it may drain battery power. Note: • You cannot cancel a Demo mode when the front panel is open. • The red lead (ACC) of this product should be connected to a terminal coupled with ignition switch ON/OFF operations. If this is not done, the vehicle battery may be drained. |
Thanks all for the responses... actually figured it out Friday just before I headed down to KC... this is the first time I've been on the board since )
Yes, it was the demo mode... hold down 5 and it stopped. Really weird it goes into this mode by default after power was reconnected. |
