Old 12-05-2005, 12:00 PM
pipedream's Avatar
pipedream pipedream is offline
Send a message via AIM to pipedream
Red "E-Brake" light remains on...without e-brake on.
As the subject says, my e-brake light has been sticking on lately. No, the e-brake is not on, but I am wondering if there are other systems that are set to trip off the e-brake warning light if there is an issue with them... is there a common issue with the svx that would throw the e-brake warning light, even when the brake wasn't set?
Old 12-05-2005, 12:07 PM
n00b on demand's Avatar
Open your hood and clean off the cap to the brake fluid resevoir. Then open the cap and close it. The light should go away. Happens to mine once in a while. Check your fluid level too.
Old 12-05-2005, 01:05 PM
dcarrb dcarrb is offline
As POWER alluded, the light does double-duty monitoring brake fluid level in the master cylinder reservoir, only it's hyper-sensitive and sometimes comes on even it the level is okay. My Legacy did this. Guess it's just a Subaru thing.
dcb
Old 12-05-2005, 01:45 PM
pipedream's Avatar
Hmm, Ok, I figured it was something like this.
I haven't noticed any issues with breaking, or any other aspects of performance of the car... Although I'm not sure what kind of change to expect from low brake fluid.
I will check the resovoir- I just had the car serviced (jiffy lube) and I think they checked the brake fluid resvoir and it was fine.
I'll check it out tonight- thanks guys.
Old 12-05-2005, 01:48 PM
Doesn't matter if they checked it....sometimes when its cold out it sticks.
Old 12-05-2005, 09:45 PM
kuoh kuoh is offline
Sometimes, it's because the bladder in the cap is stuck out pushing the sensor down.
After you check the fluid level, make sure the bladder is in the correct position before putting the cap back on.
KuoH
Old 12-06-2005, 10:37 AM
angrydan angrydan is offline
I get this 4-5 times a year. Just removing and replacing the cap fixes it for me.
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 12-06-2005, 07:39 PM
dromano's Avatar
dromano dromano is offline
wonderful info
I have this happen when the weather is cold. I thought it was an electric grimlin. Thanks for the info guys.....
2012 Outback 3.6R Limited!
Old 12-07-2005, 01:10 PM
svxash's Avatar
svxash svxash is offline
[QUOTE=pipedream]
The level in the resivoir will change as your pads wear. You probably won't notice much of a change if any when the fluid is low(unless almost empty and then you'll know!!) I just checked my wifes this morning because she mentioned that the light was on. The cap looked just like the one in the photo. Added a little fluid, inverted the bladder in the cap, and no more light. This is the second time this year but it is an easy fix.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 12-07-2005, 02:57 PM
SvX001's Avatar
SvX001 SvX001 is offline
92 Pearl/Black Fast S#!T
Send a message via AIM to SvX001
actually i hooked it up today to a load tester and my battery is good, but my auto tech teacher told me my alternator bearings were burnt out and would need to replace it soon, also my starter is pullin alot of juice out of the battery so , thanx i found my problem and it might be your problem too but hopeuflly not
