Old 07-24-2013, 07:55 PM
Jvan Jvan is offline
power mirror switch relocation
I want to add some lower fog/driving lights to the front and need a place to install switches. I never liked the location of the power mirror on the lower dash. I'd like to replace the switch w/a duplicate of the heated mirror/parking light switch (replacing the heat switch w/another light switch). I think it will make the additional switches look stock.That means moving the mirror switch. Some Subs have the switch on the center console but I think I'd prefer it on the door in front of the power window switches. Anyone have a suggestion on what mirror switch to use or even if there is enough room at that location to install a switch; suggestions for other locations?
Old 07-24-2013, 09:13 PM
Re: power mirror switch relocation
I have been down that road before.
You're asking for a lot of headaches with wiring, etc., coming out of the doors and into the dash. Not a lot of room behind the door panel for switches or wiring.
I would get another switch like the parking light/ heated mirror switch and install it where your coin holder is. You have enough room for the wiring for your lights and access to the wires you need to power it are readily available.
Same location the heated seat switches are in the Canadian markets. No cutting, modifications, etc. and is completely reversible. As stock looking as you can get.
Old 07-24-2013, 10:59 PM
Replacing the coin slot was my first choice but my wife insists on keeping the coin slot. I don't know why she insists on keeping it since it doesn't hold that much and I don't find it useful. I just keep coins in the ash tray which we don't use. Need to keep the wife happy if I want to play w/my toys.To get her permission to use the coin slot, I need to come up w/an alternative for the coins, other than the ashtray.
Old 07-25-2013, 04:50 AM
Tireiron Tireiron is offline
Alternative for coins... get an ez-pass and not need any money at tolls.
Old 07-26-2013, 05:33 PM
Tolls are not the issue. I live in an area where I rarely use a toll bridge or highway. Maybe 5/6 times a year I'll pay a toll so I don't need ez-pass (although I have other objects to it; like being tracked). The main use of coins is for parking meters (local towns don't use credit card readers). My wife keeps a roll of quarters in the coin tray and doesn't want to damage her nails by digging into the ash tray. Thanks for the suggestion anyhow.
Old 07-26-2013, 06:18 PM
I keep quarters in a plastic prescription bottle with a snap-on lid and just dump out what I need for meters. They hold a lot more than that dash holder.
It rests inside the passenger door armrest without problems and out of the way. Very easy to dump coins out of and refill. They don't rattle. Try it.
On spirited acceleration, I used to have coins fly out of the coin holder in my 92.
Don't cut your dash... trim her nails
Old 07-26-2013, 06:45 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Wow, I didn't think anyone actually used the coin holder for that purpose.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-28-2013, 08:43 PM
I need to keep the wife happy so if the coin tray does it, small price to pay. After 43 years of marriage, compromise is essential. I'm thinking that a "joy stick" type of mirror control that was used on several GM cars in the 80's/90's may work in to door since it's really small. I'd like to place it above the window switchs toward the front of the door. I guess the hard part will be extending the wires into the door thru the door jam.
Old 07-28-2013, 09:29 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Best way I've found to run wiring from the dashboard to the door - on any car - is to fish a long 1/2" dia - or smaller - clear vinyl tube through the rubber accordion cable protector, then feed your new wires through it.
The vinyl is flexible enough that there's really no reason to remove it afterwards.
Makes the job less hassle-y.
Done it a few times, most recently to run signal wires to the door lock actuator to install a secondary silent burglar alarm pager that can alert me through 12 floors of a concrete hotel or the mall...
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 07-29-2013, 01:10 PM
You lack the necessary clearance at the top of the window trim panel. Most switches are not shallow enough to work there; that's why FHI put it where it is. It is not used that often to merit instant accesability or being mistaken for other window controls in the dark.
Remember, it is a multi-contact switch, with at least 8 separate wires (up, down, left, right, x 2 mirrors)
As an attorney, you can argue a much better case for NOT doing it. The wire bundle still needs to remain flexible always.
Also, if you are running new wires, look at the gauge of wire to the OEM switch to determine the current-carrying capacity to the switch motors.
Looks like an OBDII car is not in your future...
Old 07-29-2013, 01:25 PM
I've been convinced that moving the switch to the door is not a good idea. I agree that the switch is not used that often (only when we switch drivers), so it doesn't need to be that accessible. I'll leave it alone for now, other problems to focus on.
