Old 12-04-2009, 06:52 AM
lazer lazer is offline
Car won't start
Was driving home yesterday and i noticed that the CEL came on. The car was at this stage running just fine. Turned in to my parking lot and tried to restart the engine (which worked) CEL was still present. Today the car would not start at all. I took a CEL reading and got the following code:
31 Throttle Position Sensor or Circuit
21 Coolant Temperature Sensor or Circuit
23 Air Flow Meter or Circuit
I guess every one of those codes should be fixed but:
Which one of those could make the car behave like it did?
Any suggestions on the problem?
Going out to tow the car to my garage now (Its like -3c/26f and windy outside brrr) to see if I can find any loose wires and whatnot.
Lars
Old 12-04-2009, 07:55 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Car won't start
Do the coolant temp sensor first, a leading cause of no-start..... also the cheapest.
It has been known to kick on other codes as well when it fails, and the fact that you drove home and even restarted it when it was warm would indicate the CTS has failed and is failing to indicate a cold-start to the ECU.
Old 12-04-2009, 12:00 PM
Re: Car won't start
Well had it in the garage for some time and the it would start. (a littel rugh but it started) after running for a while it started flawlessly.
Also before it heated up i tried to use starter fluid and it just backfired on me.
Old 12-04-2009, 01:28 PM
NeedForSpeed NeedForSpeed is offline
Re: Car won't start
Engine cranks, but no start? Engine doesn't crank?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 12-04-2009, 05:44 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Car won't start
Yes that would indicate the coolant temp sensor.... once your engine warmed up a little inside the CTS reading became closer to what the engine temp actually was.... its probably shorted to "hot".
Old 12-04-2009, 06:02 PM
Re: Car won't start
Problem fixed...
It turns out that it was the MAF afterall..
Cleaned it and resoldered the internal pins. All the codes went away
Thanks for all help
Lars
Old 12-22-2009, 12:12 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Re: Car won't start
I must be out of the loop..
what was your process on fixing the maf
yourself ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
