Old 11-01-2009, 02:07 PM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
headlight washers
Hello, i just had a problem on my SVX, the headlight washers are not working, water is not eject, how is it a problem ?
Old 11-01-2009, 03:22 PM
Re: headlight washers
Hard to say.
It could be:
No water in the tank
A blown fuse
Burnt out motor in pump
Loose or broken connection to the pump.
Blocked nozzles.
If the pump is not pumping when you press the button then you need to check if you have an electrical problem, and I'd start with the fuse.
