The Ultimate SVX Transmission Swap Thread
I wanted to start a thread that can easily be referred to for any info related to SVX transmission swaps. I’d like to gather as much info as possible about all of the popular options all into one easy to find thread. I think this would be very convenient, especially since the search function won’t allow you to use things like 4.44 or 4.11 as search terms.
If anyone finds anything that is incorrect, or has any info to add to this, please post here and I will try to keep on top of updating the first post of this thread. I want this to be as accurate as possible. If this turns out well, perhaps a mod could make it a sticky? Automatics: 4.44 trans swap Pros: Geared more for acceleration than the SVX 3.54 trans. Stronger gears, doesn’t have the typical failures that the stock transmission has. Better availability than the stock SVX trans and a relatively inexpensive upgrade. Cons: Freeway cruising will be at a slightly higher RPM due to the steeper gear ratios. Where to find it: These came in 2.5L legacy outbacks from 96-98. The part number needs to start with TZ102Z2... the last 3 letters only refer to the year and model of car, outback, LSi, or GT. all 3 will work, as long as the part number is as stated above. If the trans number ends with: ....BA it comes from an outback. ....CA is a GT, and ....AA is a LSi. All 3 will work. Taken from: http://www.subaru-svx.net/forum/showthread.php?t=49026 4.44, 4EAT Transmission Numbers How to info: How to instructions by svxfiles Additional Info 4.11 trans swap Pros: Geared more for acceleration than the stock 3.54 trans, but less than the 4.44. Kind of the middle road for auto trans gear ratios. Cons: A number of these swaps are failing just like the factory trans, so it may not be much of an improvement over stock in regards to reliability. Freeway cruising will be at a slightly higher RPM than stock due to the steeper gear ratios. Where to find it: These can be found in 1990-1994 Legacy's, although, some 1992-1994 have 3.90. How to info: How to instructions by svxfiles 3.90 trans swap Pros: Geared more for acceleration than the stock 3.54 trans, but less than both the 4.11 and 4.44. Cons: Freeway cruising will be at a slightly higher RPM than stock due to the steeper gear ratios. Where to find it: These can be found in some 1992-1994 Legacy's. How to info: How to instructions by svxfiles Overview of automatic transmissions: The below was taken from: http://www.subaru-svx.net/forum/show...8&postcount=22 Stock: Builds up too much heat which leads to failure of the high clutch packs. A properly rebuilt stock trans with external filter and cooler should last as long as any 4.44 (or longer). 1995+ SVX transmissions are less prone to failure as long as they have the cooler and external filter. They don't have the internal screen that the 1992-1994ish have. 4.11: Were not built to handle the heavy SVX. They have less clutch packs, so they fail prematurely. The difference in final gearing does not make up for their lack of clutch packs. 4.44: Were built for towing, they have less clutch packs than a stock tranny but the final gearing gives them more leverage and so they generate far less heat. Manuals: 5MT swap Pros: Manual transmission. Lower maintenance/more reliable than the autos once installed. Better acceleration than factory SVX auto trans. Cheaper than the STI 6MT. Aftermarket (stronger) gearsets available for the WRX versions. Cons: Not a direct bolt-in, requires custom parts (crossmember etc.), is more difficult to install, and is more expensive than the autos. Cannot handle high power levels as well as the STI 6MT, but is sufficient enough for most SVXs. Where to find it: Most Impreza and Legacy transmissions will work and also Impreza WRX transmissions will work. Part way through the 2003 model year the WRX 5MT was revised with a few changes, which supposedly makes them stronger than the earlier version (MY02 through the first half of MY03). There were also a few more changes in later model years that I do not know the details of. How to info: http://www.subaru-svx.net/forum/showthread.php?t=54258 STI 6MT swap Pros: Manual transmission. Lower maintenance/more reliable than the autos once installed. Better acceleration than factory SVX auto trans. Been proven to handle very high levels of power in stock form. Aftermarket (stronger) gearsets available. Also has the ability to use the Driver Controlled Center Differential if desired. Cons: Not a direct bolt-in, requires custom parts (crossmember etc.), and is more difficult to install. Very expensive in comparison to the other swaps. Average prices are around $4500 for the drivetrain alone, not to mention the additional parts needed to make it work in an SVX. Where to find it: MY04+ Impreza WRX STIs. How to info: http://www.subaru-svx.net/forum/showthread.php?t=54258 (This is for an older Impreza 5MT but is related to the 6MT) Driveshaft information: 96-99 legacy outback 5 speed driveshafts are the correct length for 5MT swaps. Stock SVX driveshafts work for 6MT swaps. And lastly, don't forget the additional things to do while the trans is out! http://www.subaru-svx.net/forum/showthread.php?t=38224 -Jon
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 Last edited by Coan; 10-31-2010 at 10:51 PM. |
Re: The Ultimate SVX Transmission Swap Thread
Legacy Outbacks existed only from 95-98 (I guess we're talking pre-8 bolt pattern here?) and all 95 Outbacks had the 2.2 some manual equipped Outbacks had the 2.2 (1996 only). I also don't know if the 1995 or 1996 Outback had the 4.44 (my guess, seeing as the 1995 was a rare trim level, that it would not). You would want to check the rear diff or check the transmission number to see if it matched.
4.11 auto transmissions can be found in 1990-1994 Legacy's (although, some 1992-1994 have 3.9, which is mysteriously missing from this list). Stock SVX transmissions 1995+ need not be rebuilt as long as they have the cooler and external filter. They don't have the internal screen that the 1992-1994ish have. As long as you don't drive like a race car driver, it's fine.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 10-31-2010 at 06:02 AM. |
A compilation of driveshaft lengths would be helpful to some (me).
96-99 legacy outback 5 speed driveshaft = correct length for SVX with 5 speed conversion. I'm told it will not work with 6 speed conversion.
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
stock SVX driveshaft will work for 6spd
96-99 Legacy Outback 5 speed driveshafts are not always available.
I thought this was what I have on my car (97), but it had to be shortened 2 inches and still was a tight fit (bad, I know). Should have went 2.25''.
2002 WRX, auto, non-component 57.5'' total length 24.25'' from cup to center of bearing 33.25'' from flange to center of bearing I only took rough measurements of the stock SVX shaft since it was cold and I was straddling a lawnmower. 61'' 25.5'' 35.5'' --- http://www.ncdls.net/ --- 85 Brat, 4wd, AT 51.75''
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 12-17-2010 at 10:26 PM. |
I'm asking some Ebay parts sellers to measure their 05-09 Legacy AT shafts to hopefully get an answer for this thread.
I've also added a small driveshaft section. For all of the auto swaps, the stock SVX driveshaft is used, is this correct? Thanks for the input guys! If anyone else sees anything incorrect or any other common swaps that should be added, let me know.
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
