Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 03-30-2004, 03:10 PM
sti trans rebuilt for more power
Old 03-30-2004, 03:44 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Originally posted by longassname
Yes, you are all a bunch of perverts lol
The mounting of the throttle switch... hmmm, yet to be determined. Right now i'm thinking i'm going to make a bracket on to which the nitrous and fuel solenoids mount along with the throttle switch. This bracket will bolt up to the throttle boddies so that the throttle cable apparatus there activates the throttle switch. This should make for a clean install and require only two wires..one to power and one to send ground signal to the chip. I'm going with a ground triggered system which will take ground directly from the bracket's mounting to the throttle bodies.
I chose to go with a supercharger over a turbo for better performance. It's a roots style blower which will mount directly above the engine in a new upper intake which we will fabricate. The alternator will be relocated. Since the blower is mounted directly on the intake there is no plumbing at all. The kit will compirse mostly of the chip, fuel injectors, intake manifold, blower, alternator bracket, belt. It's the best set up all around. Higher performance and cleaner install. As for running higher boost later..hardare wise the supercharger will be able to do it but the engine will need a serious rebuild first and even before that a stronger transmission will be needed. I'll be building such an engine and will be happy to share the specs when they are of use but there's no rush as there isn't a viable transmission option to handle the hp yet.
origionally i didnt use bracket, but made a small one as soon as i could, as it didnt quite fit right how it was on their.
however i just put my solenioids on the fire wall :\
phil
~Phil
Old 03-30-2004, 04:16 PM
longassname's Avatar
Just some dude.
I haven't gotten into looking at it yet but i understand the newer cars have a different bolt pattern where the bell housing bolts to the car...can you use an old imprezza bell housing with a new sti transmission..maybe I don't know
More importantly remember the wrx's are very light cars. Their transmissions, flywheels, clutches, etc aren't really up to both high hp and high weight...it's a real stretch..kind of a down grade from the svx tranny
What I've been thinking; however, is when the production model of the b11s hits the streets we aught to be able to make a bell housing to use that transmission. It's already designed to support high hp on a heavier car.
I'm sure after the need arises the guys who are doing the 5 speed swaps now will come up with something to meet the demand.
Old 03-30-2004, 04:25 PM
wawazat??'s Avatar
Yeah, I'm still around
Subaru manual transmissions, unlike their automatics, do not use a separate bellhousing like most doemstic RWD cars. The area used for the bell-housing (ineither a manual trans or an auto trans) is actually reserved for the front differential. You gotta take the entire trans and bolt it to the engine using fewer bolts than the factory intended and hope for the best.
Todd
Down to none
Old 03-30-2004, 04:27 PM
mranderson mranderson is offline
The One
Send a message via AIM to mranderson
Man its hard to keep track of this post.
Did you say that the stage 2 would actually lay down more power than the supercharged stage 3?
Old 03-30-2004, 04:46 PM
Just some dude.
They will be about equal peek hp but remember nitrous is a flat amount of horse power accross the entire load and rpm range. So the stage 2 nitrous system will be faster in the 1/4 mile which is about the only use you get out of it. Where with the stage 3 blower you have 24/7 around town power.
Old 03-30-2004, 04:54 PM
there are a couple of people running the new 6 speeds from stis already
Old 03-30-2004, 06:52 PM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
Only Alex (alex_umn) has an STi 6 speed... as far as I know. I'll also add that it drives pretty nice, in my opinion.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 03-30-2004, 07:06 PM
Hmm... aren't you worried about the roots style running a bit hot (compared to centrifugal or turbo)? Will it work very well without an intercooler? You're saying it provides higher performance due to the low end torque provided comes on earlier, right? I would think a centrifugal type supercharger would be better just due to it being more efficient.
-Aaron
Old 03-30-2004, 07:14 PM
Just some dude.
People can argue the merits of one type of forced induction over another forever. A supercharger runs cooler than a turbo in general due to not having the soak from the hot gasses running the turbo. AT 6 lbs of boost we should be fine without the intercooler. Just from general experience and their track record I think roots blowers offer more performance but centrifugals are good too.
Old 03-30-2004, 09:18 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I can chime in here as my 2000 SVT Lightning uses a Roots type blower. Yes it is intercooled, but as a supercharger compresses intake air (as oposed to exhaust gases as in a turbo) several people have been able to run a roots type blower w/out an intercooler with no ill-effects. The best thing about a Roots blower is that it makes most of it power in the low rpms (<4000 rpms) and this gives drag racers that edge at the starting line. Screw type (centrifugal) superchargers are more efficient, but way more expensive and make the most power in the higher rev band (>4000rpms).
2006 Steel Gray WRX TR (sold)
Old 03-30-2004, 09:27 PM
he's right, the roots style blower will take advantage of our motors w/ their low end power as opposed to a turbo or centrifical because they all run to make better high end and our powerband takes a dump at like 5600 so a roots is the most efficient and most powerful w/ out major engine rebuild
Old 03-30-2004, 09:41 PM
The One
if it takes a dump at 5600 why is the rev limiter being raised higher?
and yes i am dumb so if that is a really stupid question be easy
Old 03-31-2004, 05:38 AM
cdigerlando cdigerlando is offline
Intercoolers
I agree. Even at about 8 psi with a turbo, it is questionable whether an intercooler helps. Definitly not needed for a supercharger at 6 psi. There is a certain amount of work required to get through an intercooler. This added backpressure causes the intercooler or turbo to run at a higher pressure. Say 2 psi loss through the intercooler. This means the turbo/super needs to run 10 psi to make 8 at the mainfold. The compressor actually runs hotter air in this case reducing the effectivness of the system. I'm sure the break is a little different for every applicaton. An A/W might be good with low losses. Also water injection.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 03-31-2004, 09:31 AM
GreenMarine's Avatar
From POST-***** to LURKER
The STi trans could handle all the power that our engine could ever produce... Ya wouldn't have to rebuild it... Get this, it isn't even built by Subaru...
It's built by some company in Germany from what I hear... However the old STi 5 speed from the version 6 and below are built by Subaru... They are still Very strong tranny's... Also the WRX 5 speed has recieved alot of crap... In most of the cars that I have seen, the tranny's have blown 2nd gear simply because of Abuse... Yes If I wanted to I'm pretty sure that I could go out to my car right now and do a few 6500 rpm clutch drops and maybe blow 1st gear out with the estimated 250hp (flywheel) that I'm making outta my SVX... It is all about how you drive it, really... I have also seen a WRX run a 11.9 1/4 mile on the Stock tranny... It is all about how you shift... Now, sometimes with the way that I drive I would feel a little more comfortable if I had the Forester XT 5 MT in it but hey that just makes me not drive quite so hard, and probably has saved me from a few tickets...
