Fender side marker lights
Just wondering about them... I have seen them on a few SVX's and I like how they look... I was wondering where you can get them and how hard they would be to install.. thanks
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
I don't know....
But I was wondering the same thing. I like the white ones. The orange ones I have seen are not as sleek looking. I bet you just drill mount then wire??
-G |
Re: I don't know....
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Will post pictures.
lwin
i just mounted side marker lights on mine last week. i used clear with starndard orange bulb. at first i had them wired to work with the driving lights only, then we wired to turn signals only, and this is where i will leave them. the install wasn't tuff, i wanted to mount them lower then you normally see them stock- basically in-line with the front lights. i spliced into the + of the front signals, and grounded out on the chasi. the cutting was tricky at first, i started with a drill beleave it or not, then stopped when the metal started getting to hot and start to warp around the bit. i then borrowed a neumatic 3 inch circular grinder, and cut my pattern, it went fairly clean. i then filed the rough spots and then neutralized the exposed metal, then primered (with a small hobbie brush)and then drilled out the mounting holes, conditioning them as well. that was pretty much it.
keep in mind if you decide to mount lower on the panal like i did, you will need to bend some of the inner soft frame work. i will post jpgs later sunday here and locker. fyi, i did not remove corner panels to do this, simply the wheel-well liner and the front corner light was all that was needed for access. looks great on the red. also, look on ebay, currently there is a used corner panel up for auction , it has a marker mounted on it, looks stock- jimi - to sleep now Last edited by museumquality; 11-10-2002 at 03:01 AM. |
found this site that offers mini markers as well,
http://www.terrshop.com/ i will post a jpg of my lights monday jimi |
Re: Fender side marker lights
Here are the part numbers for the OEM side marker (repeator) lights. The UK-spec and the JDM parts are identical, except for part numbers. Here they are:
UK-spec repeator (right) PN 84401PA020 repeator (left) PN 84401PA030 The cost is £26.53 ($42.13)plus shipping JDM repeator (right) PN 84401PA010 repeator (left) PN 84401PA000 I don't have the actual cost on these, but they are definitely cheaper than the UK ones. Probably about $26.00 each. Maybe Lwin has the price. These are complete assemblies, with amber lenses, bulbs, gaskets, and wiring harness. Attached is a good photo of the marker. I also took measurements on this car, when I was over in England, to show the correct position.
John,
Looking at that picture, they do not appear to be inset into the fender. Do you recall if they were? I think they should be inset. I really like the new clear audi markers, I think they would compliment the SVX. I'd like someone to make a bolt up flanger to make the inset for the fender. Then won't have to take my portable sheet metal nibbler out this holiday season and get a set Doug
They weren't inset as far as I could tell. I did some very close inspection when measuring, etc. What I really wanted to do was pop out the marker and make a "rubbing" of the shape of the hole in the fender.
Speaking of side markers, I like the wraparound ones that are inset into the bumper and wrap around the front wheel well lip of the new Porsches. Visability and functionality integrated into design.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-27-2004 at 06:56 PM. |
Here are the jpgs of my clear side markers. (blinker only)
another
Hi all,
i just bought side marker lights for my SVX. I have no idea on fixing them. Some of u guys have successfully installed. Can u guys please tell me how i can install them. 1) which tools i require 2) The dimensions (HXW) 3) Procedure to install Can i install them myself and is it too tuff, I want to use them as blinkers. Thanks, Pavan. |
paddlesnz 1993 Subaru Alcyone SVX 1980 Isuzu 117 Coupe Giugiaro Edition 1999 Mazda Astina 2006 Honda Legend 2006 Toyota Mark X Premium 2007 Toyota bB 2007 Mazda Roadster RS 2012 Peugeot 208 Allure |
