Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 05-12-2013, 07:47 AM
shotgunslade's Avatar
Fiberglass Hood Struts
Has anyone done anything for permanent hood struts or props for OT's fiberglass hood?
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; 07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250 duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
Old 05-12-2013, 01:50 PM
Re: Fiberglass Hood Struts
It has been suggested to use some really weak, old hood struts, but I haven't heard how that turned out. I have a C/F hood in storage that I will eventually have to solve the same problem with. I will say however, that if you've got a fiberglass hood, then you're trying to save weight, and deleting the hood struts is in that same spirit. So I'll probably try to make some kind of prop, but I'm not decided yet.
Old 05-12-2013, 05:00 PM
92 SVX 92 SVX is offline
on the spd catalog didnt they have some 30 pound hood struts that were the same length?
It has been quite some time since I replaced my hood and trunk struts with the ones from the spd catalog but I thought I remembered seeing that.
Old 05-12-2013, 06:30 PM
Think I want just a prop, like in my Outback. It works just fine, I dont have to worry about getting the strut pressure right, so the hood doesn't fly open and hit me in the chin.
Old 05-12-2013, 06:55 PM
I've got plenty of dead hood struts anyone can have for cost of shipping.
Old 05-12-2013, 07:58 PM
I have hood struts from NAPA they seem to work.. They are worn now and only hold the hood open in cold weather. I will be replacing them . I have a part # the PO gave me. I will look it up tomorrow ..
Old 05-12-2013, 10:08 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Dan,
I use a dead pair of stock struts that OT drilled a hole through so I can put a pit pin in them when the fg hood is up.
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-13-2013, 05:33 AM
A very small pair of vice grips works for me at car shows. They are from Lowes and were $2.00
Old 05-13-2013, 06:27 AM
Nate:
Do you also have the brackets, frame and hood for the struts. Seems they were left on the old hood when OT installed. If so, I would be interested in purchasing a pair of dead struts each with hood and frame brackets. If the struts are too dead, I will follow Bill's advice, and drill a hold through the entire sturt so that I can put a pin in when needed.
2001-2015 SVX World Network
