Old 07-05-2006, 04:42 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Clear Lenses...
All of us know how the SVX lenses like to yellow and get all funky. Well I've wanted to do this for a while but finally got the motivation to fix my lenses. So I figured I'd do a little write up.
I got everything I needed at Walmart and it didn't cost more than $50 and thats because I bought the Mothers Powerball.
You'll need... 1500 grit sand paper, Bucket of water with mild dawn soap, rubbing compound, plastic polish, clean rags/ micro fiber, masking tape and a Powerball w/Drill.
1. First I started by masking off my headlight.
2.Lightly sand the headlight, making sure to keep the paper and headlight wet. Sand till the head light is soom and hazy.
3.Then rub the rubbing compound onto the light to take up most of the haze. Buff with the powerball till the haze is pretty much all gone.
4.Now put the plastic polish on and buff off to bring the lense back to clear.
5.Finally, I put some wax on to seal everything in. Now my lenses look good as new!
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 07-05-2006, 05:56 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
how long did this take you. Man i Just got done buying some new lenes from Motorsports Warehouse. Hope they look good as your do
Old 07-05-2006, 06:01 PM
gest24's Avatar
#1 6MT In Cali
About 20 min a lense. Not long at all.
RIP
84 VW Scirocco
02 WRX
Old 07-05-2006, 06:11 PM
Earthworm's Avatar
Meow!
The smallcar lenses take much longer than 20 minutes!
Old 07-05-2006, 06:18 PM
Gloomy's Avatar
Gloomy Gloomy is offline
WOW!!!!! THATS A CLEAN JOB!!!!
Is that possible to have more informations about the stiff your using?
Any pictures?
Thanks!
Old 07-05-2006, 06:46 PM
gest24's Avatar
#1 6MT In Cali
Any pictures?
Thanks!
Here you go... Sorry if the pics are large...
RIP
84 VW Scirocco
02 WRX
