Old 03-08-2005, 09:48 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
EGR system
My CEL will flicker on once in a while, and its storing a code 56 for the EGR system. I cleared the codes I was getting before (for knock and oxygen sensors, which have been replaced) but this one came up again. Is this probably just the valve sticking or gunk in the system? If so, how to clean it out? My mpg isn't very good either, under 15, although my driving is all in city and I do have a lead foot. I'll will be taking it on a long drive soon so I will check it again then. Other than that, the car runs great. Thanks in advance.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 03-09-2005, 03:02 PM
blacknite blacknite is offline
check all the air hoses for any licking maybe when you replace the knock you left something loose and if you found one make sure to reset the computer. did this happend after the replacement of the sensors?? hope this will help
Old 03-09-2005, 05:16 PM
AFBeefcake's Avatar
Subaru Swapper
I cleaned my EGR system out with brake cleaner and CE when away. It was a pain to remove the valve. Allso check the vacume lines the run to and from the EGR valve. Clean out the hole in the intake manifold where the EGR tube runs in, mine was all most pluged completly.
think it would be eazer to fix if I knew what the ECU is looking for when it comes to EGR. The only thing I can see its the EGR temp senser on the top of the intake manifold. which would explane why the code went away after I cleand out the tubing.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-09-2005, 05:55 PM
nordique14's Avatar
nordique14 nordique14 is offline
Who watches the watchmen?
Check to make sure that code 56 is the only stored code. I was getting a 56 and a 21 (coolant sensor). Once the sensor was replaced the code 56 never returned. The EGR system will have problems if some other sensor is not working properly. If you do not have other codes, then it is probably a vacuum leak.
-Matt
Old 03-09-2005, 06:00 PM
Long Time Ago Someone Post An Advice "when Having A Whole Lot Of Codes From Ecu Got Start From The Chipest, One By One Reseting The Computer Each Time" Every Part Is Made To Work With Another..
Old 03-09-2005, 06:09 PM
Just A Couple Of Days Back I Removed The Hose Or What Ever Is Called Where The Air Travel In To The Intake. When A Put It Back Together A Forgot To Plug One Of The Hoses. And I Started To Get Code For The Purge Selenoid (sorry For The Mispell). I Search To Get More Inf. Here But Nothing Real. So I Check The Car For Anything. And I Found The Hose That Wasn't Conected To The Intake. Put It Back Reset Computer And Problem Solved!!!!!
