Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > European Forum
Old 09-22-2010, 02:49 PM
DJW svx DJW svx is offline
Dip stick is popping up
In conversation with Joe at the week-end it was mentioned that if the PCV valve (not sure if I've got that right) has gone if your dipstick pops up, well I had noticed in the past that mine had. So yesterday I gave the car a fast run and guess what my dipstick had popped up so I have this problem can anyone advise please.
Old 09-22-2010, 02:59 PM
Re: Dip stick is popping up
Try the "O"-ring on the dipstick first. If that doesn't fix it, then yes, your PCV will need to be replaced.
Old 09-22-2010, 03:00 PM
Hi David
This is dealt with and explained in the How To documents at the top of your page on the right. It is listed under Maintenance, though you could make a case that it should be under Engine. [Or maybe both ]
Here is a link to the PDF
It is a simple thing to fix, other than it is in a bad place and requires some "keyhole surgery" The leaflet explains it all very well and what you need.
Old 09-22-2010, 03:07 PM
Yeah, we mentioned that at the meet Nate.
I'm not a fan of it as much more than a temporary cure though, the "O" ring I mean. I can't shake the feeling that if your crankcase is under that much pressure, this pressure could be a cause of forcing oil through the front engine seals and the cam cover gaskets. You know the ones I mean, the leaks that keep dripping on the exhaust.
To me it would seem to be better to keep the crankcase pressure at a reasonable level rather than just masking a symptom such as the dipstick popping.
Old 09-22-2010, 03:40 PM
Yes, very true. I just got my silver back on the road and it has had issues since shortly after I bought it of the dipstick popping up as well as oil leaks from everywhere. Upon putting in a transmission, I noticed a lot of oil on the intake snorkel so it appears as though I should really do this before the car gets put away for the winter months here. Who knows, maybe it will help all the other leaks.
Old 09-22-2010, 03:51 PM
Can't hurt?
Old 09-22-2010, 05:18 PM
oab_au oab_au is offline
It is not only the PCV valve, but the cam cover breathers that run to the air duct. as I posted here .
http://www.subaru-svx.net/forum/show...9&postcount=15
Oil in the air duct and right back to the filter element, is a sure sign that the passages in the air duct are restricted.
One Arm Bloke.
Tell it like it is!
Old 09-23-2010, 12:29 AM
Thanks for that, I thought it had done it before and I now know it has so I'll go about it.
Old 09-23-2010, 12:12 PM
Just a quick one is it a standard Subaru part you can buy from a Subaru agent.
Old 09-23-2010, 02:11 PM
Sean486 Sean486 is online now
Out of curiousity, how would one correct this condition Harvey?
Old 09-23-2010, 02:19 PM
Cam Cam is offline
I realize that question was asked to harvey, but you would need to replace the lines and breather gaskets. Clean the breathers before reinstallation.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 09-23-2010, 02:48 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
You might quit dropping those little blue pills in the gas tank and driving past Hooters.
I don't really know what all that means. (Sorry I am kind of dumb about engines) I guess what I am curious about is; whether it is a very difficult or very expensive repair, or is it something relatively easy to have done.
You know, how accessible are they, how much of the engine has to be disassembled to get those lines and gaskets.
Old 09-23-2010, 05:09 PM
Beav, I don't think THAT was the stick he was worried about.
One Arm Bloke.
Tell it like it is!
Old 09-23-2010, 05:22 PM
Sean all these passages are in the 'air duct/box' that connects to the throttle bodies. You will see where the two breather hoses from the cam covers plug into the sides of the air box, they both end up going through the small elbow pipe on the right hand side of the air box, to the air delivery pipe. They need to be cleaned out.
One Arm Bloke.
Tell it like it is!
