Old 07-03-2009, 01:48 AM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Overheating, First thing to do... try the HG Test.....
Edit: Go to the last page for latest
hg-test.wmv - 5.68 MB. This is 2 videos I made while doing my HG test... Combined into one file.
My test drive to get her warm was a mere 1.9 miles (my "test drive" route)
First leg is a 4 lane with Turning lane, 40mph speed limit, but at 3am at night, I go alittle faster. Second leg is Residential, 30 - 35mph. One big circle
by the time I was less then a few blocks from the house, my temp was reading dead center.
Once I got home, I took a towel and removed the Rad Cap. I am glad I got a towel and not just a small rag
Anyway, I tried filling it up with water, but I had the water pressure from the hose too high, and it just made it go everywhere (which is why at one point in the video, you hear the belt squeak)
After that, I lowered the pressure on my water hose to a trickle, refilled, and did the first test video.
then, turn the car off, refilled (which didn't take much) and did the 2nd test video.
Tell me what you think.... I feel its the HG, but maybe I am wrong? (that would be nice)
Also... if it is the HG... I will be doing it myself. However, It will be the first time I've done any major work to an engine. I will plan to set aside 2 full days (which is all I can get in a row) to do this.
is there a good how-to out there? Do I have to pull the engine out or can I do this with the engine in?
Just point me into the right direction... as I wont let something as small as a Gasket let Calista go down!
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 07-03-2009, 06:49 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Overheating, First thing to do... try the HG Test.....
From the video, i have no idea if it's the HG's. When you rev the engine, the waterpump spins faster and will cause an open radiator to spurt.
Does it overheat? Do you need to add coolant? What other sympoms are there??
If you're going to do the HG, pull the engine. It can come out in under 2 hours.
Old 07-03-2009, 07:09 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
For safety, you should NEVER open the radiator cap when it is hot!
Old 07-03-2009, 10:48 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Before you do anything crazy, go rent or buy a block tester kit. It consists of a hollow tube with a coned rubber plug you stick on top of your radiator cap hole, fill with this blue fluid, and run the engine watching for a change in the fluid color. If it turns yellow, bam, its a HG. Makes diagnosis way easier.
Old 07-03-2009, 01:46 PM
Wikedjuggalo's Avatar
Rebuilding
These do not work well on our engines. Ask YT why but if I recall its mainly from how our HG leak.
Old 02-03-2010, 10:51 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Post #4
This is really worth a shot to try, may save you a LOT of work.
Old 02-04-2010, 05:34 AM
nsm484's Avatar
Teh Geek
I have a block tester, tried it a few times.... which I belive I posted before in this thread, Also, the day I parked her, out of no where she starting running oddly. I can't describe it as its been months since I've drivin her, but after that happened, after all the problems, and doing the block tester a few times which both came yellow within the 2nd pump of the tester.
Edit: I did post earlier in this tread about my block test... 2nd page:
Originally Posted by nsm484 View Post
Also, just to update... I did buy a Block Tester. I Syphoned my fluid out of the rad. just enough to make sure it didn't get sucked into the tester.
I did the test 3 times, going nice and easy on the ball as to not suck in air too fast, And each time... It changed to yellow fairly quickly.
Old 07-03-2009, 01:56 PM
nsm484's Avatar
Teh Geek
Its starting to get hot even comming to work (3/4 or higher on a 15 min drive) however the other day when I was geting my running done.... She was steady on the hot line... Then on the last 3 miles heading home she was in the red.... Then once I stoped at the house she droped back to the hot line before the red.... And I had alot of bubbling in the overflow tank.
Calista is my current daily driver.. So if you need any more info I will provide it when I get home (on break typing from my iPhone)
Old 07-03-2009, 02:00 PM
Rebuilding
I don't want to be the one to tell you the bad news ; ;...
Old 07-03-2009, 02:41 PM
So I will. Your headgaskets are leaking and you need to replace them
Old 07-03-2009, 03:00 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Couldnt a bad thermostat cause the same symptoms?? Id at least have him try that since its cheap and easy before sending him to the executioners block yanking his engine....... When mine overheated from the bad WP, I went into the red and was boiling into my reservoir as well, but my HG are fine, zero issues after i did my plugs.
I mean, unless you WANT to yank your entire engine to reseal it or something.
