Old 06-14-2008, 06:28 PM
Re: Motor Week '91 SVX Road Test Video
Originally Posted by mysvxrocks View Post
Speaking of wipers, is the first intermittent setting supposed to go to continues mode when you get to like 15mph? I find that very annoying...
/hijack
No, but it does speed up as you go faster. Actually what it does is just go slower when you are coming to a stop. All the intermittent settings do. It shouldn't wipe continuously unless you set it to one of those speeds.
Originally Posted by tiv0 View Post
yeah, sorry for getting off topic, but what exactly does that switch do
ive flipped it both ways and theres no noticable difference
When you set it to "on", it should set the wipers resting position about 6-7 inches up so you can pull them off the windshield when you park in snow, and it make de-icing easier. Set to off, they should rest low enough that you cannot raise them without hitting the hood. Mine a re a little wobbly and don't rest correctly. It's an age thing.
Old 06-14-2008, 08:06 PM
kwren's Avatar
kwren kwren is offline
That would because of the voltage generated by the alternator decreases at lower speed, depending on the electrical load.
Head lights on etc
Old 06-14-2008, 08:16 PM
the only vehicle speed sensing the wipers do is when the intermittent wiper is on the full setting... The wipers will not stop during driving just like they would on the slow setting. BUT once you come to a stop, the wipers run an intermittent cycle. Once you begin moving again, they return to a constant pace
Head lights on etc
Are you sure? But is that a side effect or intentional design? My money is on it being intentional. My wiper speed doesn't increase with rpms when stopped.
Old 06-14-2008, 08:45 PM
kwren's Avatar
Is the way the alternator thingie works... It is more noticeable when headlights are on bright climate control fan is running full blast. I always drive with all this going on and when stoped at a light sometimes will just switch the lights to lo beam and see a pickup in wiper speed.
Old 06-14-2008, 08:51 PM
kwren's Avatar
I think it is a current thing. faster alternator RPM... more current through the circuit...slower alternator turning causes less current.
Old 06-14-2008, 08:52 PM
kwren's Avatar
Trevor will know!
Old 06-14-2008, 09:09 PM
kwren's Avatar
pretty sure
Old 06-14-2008, 10:11 PM
oab_au oab_au is offline
In my RHD 95 Aust model, the intermittent speed increases with speed. It is an intentional thing I think, not related to the alt output, unless the battery is low.
One Arm Bloke.
Tell it like it is!
Old 06-14-2008, 11:03 PM
kwren's Avatar
Mine seems to vary with the difference in how wet or dry the windshield is, but not even sure about that. I thought that was a load current thing also.
I always have said these cars are interesting animals!
Keith
Old 06-14-2008, 11:09 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
The wipers are designed to vary their speed with the vehicles speed. They started this in the XT6 (maybe XT)
Old 06-14-2008, 11:19 PM
kwren's Avatar
If that is the case, the switch, or something else in the circuit isn't working.
It is supposed to change where the wipers "park" either down out of sight or up on the windshield where you can see them.
Keith
Old 06-14-2008, 11:24 PM
kwren's Avatar
Thanks, Dave! That is certainly believable. They gave us a lot of nice stuff in our cars.
Could additional wiper speed variances occur as a result of the electrical load and voltage differences from the alternator say... Idle with a bunch of stuff on to say 40 mph?
Keith
Old 06-15-2008, 05:27 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Keith
so if the switch is on wintermode the wipers will "park" higher on the windshield than they would otherwise. but when you say "park" do you mean when they come to a rest when the wipers are still on? or when you turn them off? or both?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 06-15-2008, 08:38 PM
kwren's Avatar
on my SVX with the wipers are sitting in the off position up on the windshield, i turn the switch and they make a full swipe up and come back down to rest in the out of site position. If they are in the out of site position, turned off, flip the switch, a full swipe and come back to the position on the windshield that allows them to be seen. I don't flip that switch with the wipers running. Only when they are turned off.
Hope that explains it.
Keith
