Power Steering Questions
I had a new p/s pump and re-built rack and pinion put in one year ago. I just realized today that it has the wrong fluid in it. I think it is a clear colored G.M. product. I can now hear some squeaking in the car when I turn the wheel. They're is some slippage when driving and it also has become harder to turn the wheel. I felt some slipping a few months back for a few days and then the problem seemed to go away. Now it is back with the cooler weather a lot worse. I have changed the o-ring before but not recently. I'll do it again. Can someone tell me how to drain the power steering completely so I can put in the correct fluid. I'm hoping these two steps will fix the problem. Any other ideas welcome for consideration. Thanks.
Mike
95 Pearl Blue L |
Do the O-Ring first....
Then try some "Lucas Power Steering additive"
P/s
Thanks Huck for the fast reply. I have no room to put in the Lucas product unless I remove some fluid first. No loss of fluid. I have used it with my old rack and got immediate results. Going to do o-ring today and go from there. Thanks again.
Mike
95 Pearl Blue L |
Just draw some out with a turkey baster...then add the Lucus Additive..
And remember that you use transmission fluid - not PS Fluid.
If you want to get most of the old stuff out, you can disconnect the low pressure return line. Then start the car and turn the wheel back and forth. It's gonna make a mess, but when my hose dry rotted, that "method" did a very effective job of emptying all of the fluid.
If you add ATF as it pumps out all of the other stuff, you should be able to replace most of it...
