Old 09-29-2009, 01:44 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Re: How To Do the Bosch Relay Mod???
Originally Posted by Elaine View Post
Australia vs. New Zealand... it's always interesting...
Let me bring my Canadian perspective to this. To me the main purpose of this forum is to provide SVX owners the opportunity to learn. By reading all these posts I learned that the main reason for my SVX starting problem is the key contact and nothing else (thanks Trevor!). I also learned how to fix it (thanks oab_au).
Without being mean I encourage some people here to be more receptive to these facts:
1. At a given voltage a lower resistance will draw a higher current. (Ohm's law).
2. Ground and Earth are two different things. Depending on the application they may be connected together but it's not a must.
3. There is no generic relay (including most of the auto ones) with a GND connection. However, depending on the application, any relay pin can be connected to GND.
4. The fuse shown in oab_au's diagram is necessary. In a car, with a few high current exception, every circuit is protected by a fuse. There are several reasons for that and some of them may not apply to the Bosch Relay mode. But, ask any electrician, it is much easier and cheaper to replace a fuse than melted wires and relays.
5. The fuse protects the circuit that powers the starter solenoid. The relay coil is not part of it so don't count on it to act like a fuse.
Hope it helps,
Elaine
subscribed because ladies rule and I may be performing this band-aid.
Marisa
Old 09-29-2009, 08:30 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by Trevor View Post
Keith,
There is no "connection directly to the relay and through the relay points directly to the starter."
In my world there is...
Keith
Old 09-29-2009, 08:31 PM
SomethingElse's Avatar
word words wording
Originally Posted by LetItSnow View Post
Ut oh. I'm getting a CEL now, and it happens to be related to having the clutch pedal down when the cruise is turned on. A couple of times when I've noticed it, I hit the dash cruise button (turning it off) and the check engine light went off immediately. It's super nice to be able to start my car 100% of the time, but I'd like to have this refined.
I had the same problem..take that band-aid off
This thread should be locked soon
Eric
Old 05-17-2012, 08:12 PM
Wikedjuggalo's Avatar
Rebuilding
Before I get flamed for reviving a dead thread, I wanted to provide some feed back.
I had this issue randomly. Over the past few months it has gotten very bad. An embarrassing moment of being stranded at the gas pump I finally did this. Problem would happen once in a while and not persist after that.
I opted to connect to the battery with a 30amp inline fuse. I will report back later with results on it, as I was not able to fix this by replacing the relay under the dash (because it did not exsist, possibly due to not having a factory alarm).
As for having a 5spd, I test the cruise control on, went to neutral and gear with clutch. Did not have check engine come on. Not sure why but just throwing it out there. Will report back later if I have it not start.
Old 10-11-2014, 06:26 AM
I know dead thread but read this.
Originally Posted by Starter relay bypass installation, Author: Dannmarr
ALERT! With this installation, DO NOT shift into park or neutral while the cruise control is activated. The cruise control is grounded through the starter and will activate the relay and starter again! Just remember to deactivate the cruise control before you use park or neutral.
This only pertains to the Auto is that right. Once it has a 5 speed will the BAND-Aid still work. Any one have a problem after all these years of using it? Would changing the under dash relay be worth a shot 1st ? Mine has only done it 4 or 5 times in the last 100's of starts, and 4 years. Can this be done topside or do u have to go under the car?
Old 10-11-2014, 08:26 AM
Perhaps you wired it wrong. Mine doesn't automatically start if the cruise is on.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 10-11-2014, 09:18 AM
I have not connected it at all. Just checking before I do.. Solved you problem?
Did you do it from the top..?
What relay is used. # brand ?
Old 10-11-2014, 10:24 AM
92 SVX 92 SVX is offline
I have seen it do what danmar has posted, but there were other factors not sure why it did it, but I had been messing with the switches and the dash gauge cluster this was with my 6 speed in. after doing more messing with, namely pulling switch pod out unplugging and checking wiring it stopped doing this.
Old 10-11-2014, 12:03 PM
i used bosch relay #12033862 but any relay will work. it was easily done from the top. i replaced the relay on the column with the same number relay and that actually solved the problem, i just did the relay mod for a little extra piece of mind. i do this to lots of cars that have too many relays in line of the start signal.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 10-12-2014, 05:11 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
My 92 with the Mod and cruise ON will stall if put in P but the starter is not activated.
Old 03-31-2020, 03:02 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
I love reading thru this stuff. Personally, I suck at wiring and never
did study electrical engineering. But there are the guys who know this
stuff like its nothing, and then guys like me who have to read thru it
10x to begin to get or even attempt the mod. On a positive note, Im
educating myself all the time, when it comes to electrical but for some
reason, Im still at the basics.
Anyway, cool write up, and for those who are really good at this stuff
I admire you all and thank you for putting up with slow pokes like me.
One question, this is for when using a 4 prong 30a relay (brand really
not important), personally I do like Bosch and Hella.
Would there ever be a need to use a 5 prong for this mod ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
