Radiator Fan speed
Well I checked over my motor since I got the thermostat and rad cap replaced AGAIN since the one I put in 2 weeks ago were junk and I noticed that my driverside fan spins good, sits flush and is closer to the radiator. I then looked at the passengerside and the fan wasn't spinning at the same speed as the other side, has a slight wobble to it, and it looks like it sits more away from the radiator as the other fan sits closer. Any thoughts?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: Radiator Fan speed
Pull the fan assemblies off of the radiator and check the nut that holds the fan blades to the shaft. Take it off and pull the fan blades off the motor shaft, check for wear. Also check the the bolts holding the motor to the shroud.
Ok I'll check the blades tomorrow. Also whats the proper voltage for the motors as I might as well check that stuff too. Thanks
The fans run at I think three different speeds depending on different parameters. But they should run at the same speed.
so... ....when are you gonna do your HG's
I'll do them when hell freezes over Like I said it's fine know after another new T-stat and rad cap, but I want to go over ALL things related to the cooling before I even hear HG.
Seriously though, id replace the pass fan then, wobble on any rotating object affects efficiency and speed by increasing centripetal resistance. A slower spinning fan hence cant pull as much air, and our grilles are restrictive enough. Edit: Irk yeah I forgot about the fan nuts..... In my humble defense I "sleep" in a room with a cat and 4 kittens, about 3 hours a night nowadays
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 09-17-2009 at 09:45 PM. |
LOL one day in the future.....
Well I took out both fans and the pass. side feels like it has more resistance than the driverside fan by turning them by hand. Also I don'tnow if this is correct or not but the pass. fan has 4 big blades and the driver side has 5 skinny blades?
