Leaky Exhaust around 2 to 1 Cat...rusted bolts/nuts and flanges
The joints around my two front inlets on the 2 to 1 cat are leaking. I did some research on this site and purchased the exhaust donuts, bolts, springs, etc. needed to fix the leak. However, when I went to do the work this weekend I chickened out as the existing setup is very rusted. The flanges on the catalytic converter look strong enough but the flanges on the two forward pipes look like they would not last through the repair due to the amount of rust. The nuts on the bolts were basically knobs sticking out of the rusted pipe flanges and I did not know where to even start to remove them without breaking the flanges.
Does anyone have a fix for this situation short of new exhaust pipes? Can new flanges be installed on the old pipes? If I needed new pipes, what would the $$$ damage be approximately? Note I have already fixed the leak somewhat (noise is not bad right now but water leaks out of the joints upon startup) with some high temp epoxy (says up to 500 degrees) but I don't want to create a permanent, inflexible exhaust system and I know the epoxy will eventually fail. |
Cut the bolts off with a cutoff wheel or grinder!
Cheers, John |
I think if you break the forward flanges, any exhaust shop could repair them for cheap. I guess it depends upon if the flanges break, or if they tear away from the exhaust pipe leaving a gaping hole. I like the idea of cutting the bolts since you have new ones.
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
I had the exact same problerm on my 96. The flanges on both sides of the gasket rusted away and the gasket inbetween disintegrated. This let cold air into the system and set off my CEL light for the third O2 sensor.
I would cut the exhaust pipes just behind the front cats and run 2" O.D. aluminized exhaust pipe back to a Magnaflow hi-flow converter (Which has two 2" inlets and a single 2.5" outlet (This will connect to the rest of your stock exhaust system) Many members here (including myself) have gone this route. The Magnaflow converter is available from http://www.performancepeddler.com The cost is about $95.00, but you can email them your best offer (I got mine for a litle over $60.00 shipped to my door) http://www.performancepeddler.com/de...CT_ID=MAG94007 http://www.performancepeddler.com/se...94037&x=7&y=14 Since your SVX is a 92, it has only two O2 sensors, you can use the Magnaglow 94007. Or just get the 94037 and plug the sensor hole with a screw-in plug. Also check this thread: http://www.subaru-svx.net/forum/show...ight=magnaflow .
I might have to do this, too, for my 94 LSi. Which magnaflow do I need? Also, sould I trust someone like Midas for a job like this?
I had this same exact problem and bought some used pipes locally, but I was unable to unbolt the old ones because of rust on the manifolds! I just used a grinder and scraped off all the junk, replacing the gaskets and bolts. I already sold the two pipes or I'd help you out . If I were you I'd have them cut off the flanges and weld new ones on.
Brian |
Midas, and most major muffler chains don't like to mess with this stuff. Your best bet is an independent muffler shop. It will probably be cheaper as well. .
