Radio went Quiet
Cruising to work this AM, listening to the radio, I popped in a cd. No sound came out. Popped out the CD to return to radio, still no sound except faint sounds of the broadcast at max volume.
I can hear the radio over all 6 speakers with volume at 100%, but only slightly. All functions work in both radio and CD. This is the original radio/CD setup. The Question: Is there an amp exterior to the radio, or is it time to go radio shopping?
Dave W. ______________________________ 1996 Redd Last edited by wynndi; 08-14-2003 at 11:40 AM. |
So you only get audio if you put on the radio, right? Not from the CD.
Does the CD still spin? I dont recall but is there a mute button on the SVX system, if there is check it? |
Yep, CD spins, acts like everything is ok.
The radio broadcast is extremely low, and only audible at 100% volume. I have never noticed a mute feature, but the symptoms would support that IF there is a mute......
Dave W. ______________________________ 1996 Redd |
There is no mute that I am aware of.
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
Sounds like a wiring aberration. Did you pound on the dash with your fist yet? Worked wonders with my '53 Olds AM radio.
Ron (fixes audio systems cheap).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Oddly, it all seems to be associated with the CD I was trying to play. I don't know why, but when it's in the player, the whole problem occurs, problem remains when it's ejected, but when I put in a different cd, the problem stops. Everything works as long as I keep the Japanese CD away.
The CD in question is a Japanese import, but that shouldn't make a difference....go figure!
