Old 04-28-2006, 11:19 AM
Green1995SVX
Early shifting out of first gear.
So here's an annoying problem i've never encountered before. Our 94 svx, which has an almost new subaru reman tranny, will not hold first gear higher than 4500rpms. It shifts out if first gear at about 4500, even if I drop the shift selector to the "1" position. Any idea why? Everything else seems to be in good order as far as the transmission is concerned.
Mike
Old 04-29-2006, 10:03 AM
Green1995SVX
bump? 67890
Old 04-29-2006, 11:13 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
and that shift is out of first gear at 4500 all the time?
how about the other gears? they shifting out properly?
Old 04-29-2006, 12:09 PM
Green1995SVX
Yes, without exception, it always shifts from first to second gear at 4500 rpms or lower. Never higher. All of the other gears behave normally.
Old 04-29-2006, 01:19 PM
intelisevil's Avatar
<<<Alcyone
With your engine and transmission warmed up and the gear selector in top gear, if you put it into POWER mode, (rapid movement of accelerator pedal to the floor to light the POWER light) and keep it there in first gear, does it still shift at 4500 rpm or earlier?
It's normal for the transmission to upshift to 2nd with the gear selector in 1st to prevent damage to the transmission. It will also upshift to 3rd if the gear selector is in 2nd.
Dan
Old 04-29-2006, 02:29 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
any chance you could put a Select Monitor on to see what the car is "telling you" when this happens? Have you run a trans diagnostic to see if any codes are hiding out?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-29-2006, 09:23 PM
Green1995SVX
Dan
Yes, it shifts at 4500 NO MATTER WHAT. I understand what an svx transmission is supposed to do. It is not behaving properly. It will never, ever, under any circumstances, hold first gear higher than 4500rpms regardless of which shift map is selected.
Old 04-29-2006, 09:54 PM
SVXRide's Avatar
Mike,
Maybe the trans is just trying to keep you from getting a speeding ticket?
-Bill
Old 04-29-2006, 10:12 PM
Green1995SVX
Originally Posted by SVXRide
Mike,
-Bill
Oh, of course! I feel much better about it now!
Old 04-29-2006, 11:47 PM
Green1995SVX
Well I was just out trying to diagnose the problem and got a ticket for 'careless driving' nice.
Old 04-30-2006, 06:38 AM
immortal_suby's Avatar
Thread Killah
I'm sure you have a spare TCU laying around somewhere - try swapping it out.
Locker Link
2015 BRZ Limited 6MT
Old 04-30-2006, 11:05 PM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
have you read the tranny codes?
Old 05-01-2006, 09:57 AM
Green1995SVX
There are no stored or current tranny codes.
Old 05-01-2006, 10:12 AM
SVXRide's Avatar
Mike,
"Careless driving"? You? I can't believe it
Given all the parts you've got lying around (in addition to extra snorkuses ) I'd suggest swapping out the ECU first to see if there isn't an issue with it telling the TCU that it "has" to shift. If this doesn't fix things, then I'm with Matt on swapping out the TCU.
-Bill
Old 05-01-2006, 10:21 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Mike,
Have you checked the TPS? Is it set at 0.50V?
2006 Steel Gray WRX TR (sold)
