#1546
Re: SVX Engine cooling "Again & Again"
Did some more testing, looks like my current issue is a headgasket. I'm gonna cry. It would've been nice to know about it while the motor was still out. It was obviously bad when I bought the motor but I wasn't told. Now it's time to buy a set of cometics and lots of random gaskets and pull the motor out again.
#1547
How did you figure it was a HG issue? Did you have white washed spark plugs?
#1548
One way to evaluate is analysing the CO2 in the cooling system.
See post #13 http://www.subaru-svx.net/forum/showthread.php?t=58585 /T |
#1549
#1550
oh ****, yeah that things toast.
I saw the CO detector post, I might snag one myself before I go through the trouble of welding up a new thermo housing. Thank Tireiron! |
#1551
#1552
Have removed
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 09-26-2013 at 12:13 PM. |
#1553
I'm currently working on chopping and fiberglassing my bumper to increase airflow. Might be switching to an inline thermostat this fall when funds become available for aluminum welding gear. |
#1554
Have removed
#1555
and for what it's worth, my EG33 with a massive radiator doesn't have cooling issues. In fact, after sitting in 100 degree weather in traffic, the fans RARELY kick on. I once did a test last winter, idled the car for 2 hours straight. Fans never came on. Unplugged the temp sensor and they kicked right on (This was just to verify that the sensor was working). So although I can't speak for high-rpm cavitation, I can say that a bigger radiator will keep it from cooking. |
#1556
I'm still unsure as to how that's possible cory. We have the same style radiator (cross flow). Maybe adding a divider into the tanks to keep the hot water from going straight across the top fins down into the water inlet would help?
My fans kick on even while driving, even tho it's rated for up to a 5.4liter V8. |
#1557
So the flow is from top right INLET <<<<<<<<<<<<<<<<<<<<<<< D<<<<<<<<<<<<<<<<<<<<<< O---------------------------- (separator between the 2 cross-sides) W>>>>>>>>>>>>>>>>>>>> N >>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>> To the bottom right OUTLET And then back across through my funky crossover pipe, And up in a U into the thermostat cover. So it's traveling twice over the cooling area. Essentially I have a radiator that's twice as wide as yours (But half the height) Last edited by BRZCory; 08-13-2013 at 11:41 AM. |
#1558
For yours you'd need to split the "intake" side in half, and move your outlet to the intake side. Then it'd be an exact copy of mine. To get "S" action, you'd need to do it twice (So two divisions on the inlet side, and one on the outlet) though I don't know how much coolant flow that would restrict (that's a LOT of piping) |
#1560
I wouldn't switch my outlet/inlet sides, I have opposed inlet/outlets I'd just divide the tanks.
