#76
Well just an update from me and Happy New Years....I just installed my rebuilt starter and the car starts right up everytime, no probs and now I'm happy.
#77
Grest news Matt.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#78
Fairy Story ?
It would be much appreciated if someone, other than the author, can advise if this arrangement does in fact exist.
#79
That's a pretty common arrangement/method for automotive starters since the 1950s. Others would include physically mashing a pedal on the floor to push the starter drive forward and closing the main contacts or the Ford method of using the backside of the field coils to magnetically pull a lever yoked to the drive. The Ford starters used a fender-mounted starter relay vs. the dual-duty solenoid typically found on all other makes.
I'll guess that most here are going to find that this issue stems from either the ignition or inhibitor switches. Certainly, weak solenoids are a common issue for Japanese starters but I've found that rare for SVX/Subarus. I suppose it's due to the mounting position, away from the heat of exhaust.
#80
Thanks for the input Beav. I am aquatinted with the types of starters you describe. I well remember a 1937/8 Oldsmobile I once had the use of, which had a foot pedal engaged and energised starter. Also English systems with a simple inertia only engagement of the pinion. What about Henry and his very sensible integral system on the model T. I am also conversant with modern soft start systems, whereby there is a split winding on the solenoid arranged to provide a sequence of operation. The starter motor is in series with a winding which forms a series resistance when the start signal is first delivered, so as to turn the motor a little. A primary winding with a direct ground connection, is energised at the same time, resulting in the solenoid armature moving inwards to first engage the pinion and subsequently close the main contacts, so as to supply full voltage to the motor. The delay times are dependant on component bulk and inertia. The point is that this modern soft start arrangement does not require extra sliding contacts as has been stated by Harvey. The JDM and Australian models have the usual soft start arrangement. Why would the US model have something weird, inferior and different?
#81
My haynes manual for the 5MT USA Legacy shows "clutch" and "neutral" switches to prevent the car from being started when it is in gear . These switches are not fitted to the UK model.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#82
Note -- "Toms hammer methoid, shakes the solenoid armiture loose, so that it will slide up to the motor contacts." This indicates the contacts mentioned are integral with the starter. N.B. -- "it also switches the pull-in circuit off". This action would require the opening of contacts." On further consideration, it would appear that a description of how a soft start system operates, with emphasis on the US model, has been studied, but has not been properly understood. The pull in circuit is not in fact turned off and importantly remains in circuit, otherwise the solenoid would not open, when the start signal circuit is de-energised. As a result, it would appear that a wrong conclusion has been reached that the US system is different from the Australian and JDM arrangements, as illustrated within the manuals on hand. These do not show the details of the solenoid assembly, which in fact includes a double wound coil and the circuitry involved.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 01-08-2007 at 04:55 PM. |
#83
Setting it straight.
First, the starter motors are the same on both US and others. As Phil says the US model
has a few more series switches, that our model does not. The whole trouble stems from the level of current that the starter solenoid draws. It is this current that burns the contacts on the ignition switch, and the inhibitor switch. Ill explain what goes on in this circuit of the starter solenoid. Here we have the circuit, that shows two windings on the solenoid. The Pull in and the Hold in windings. When you turn the key, the current flows through the hold in windings to earth. It also flows through the pull in windings, to the starter terminal, to start the motor turning the gear, as it is pulled into mesh with the ring gear. A resistance measurement from the spade terminal for both these parallel circuits reads about 0.4 ohms. At 12 V this is 30 amps, at 10 V is 25 amps. When the armature reaches its full travel, pulling the gear into mesh, it turns on the main contacts to the starter motor. This turns the pull in coil off by connecting 12 V to both ends of the winding, leaving just the hold in coil engaged, while the starter turns the engine over. When the engine starts, and you let the key back, the 12V positive is removed from the spade terminal, to leave the two windings connected in series to the 12V from the main starter terminal. This causes the current to flow backwards through the pull in windings, and forwards through the hold in windings. The two magnetic fields are cancelled, and the spring pulls the armature away from the main contacts to turn the starter motor off. So if you have this problem, certainly do the trouble shooting, to find and replace the burnt part. Then fit a 30 amp Bosch relay to the solenoid to remove this high current flow from these components, so they wont fail again. Harvey.
#84
It is now confirmed that the original wording, switches the pull-in circuit off, was incorrect as I pointed out. As I was aware, the circuit is bypassed, not switched or opened. The original description should have been worded, bypasses the pull-in circuit." The coil in fact remains in circuit as an essential factor. If the circuit was switched off, the solenoid would remain locked in after release of the ignition switch.
It is now noted that the wording has been amended to read, turns the pull in coil off, which is still not correct and should read, bypasses the pull in coil. Qualified engineers are careful to use correct and exact language for obvious reasons.
#85
Re: Lets talk about this annoying hot start problem...
bump for another no start thread
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#86
Yeah, I've got this clicking business going on too, with the Bosch 30amp relay attached. I just think my starter is shot. Anybody have some tips on removal and replacement?
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
#87
Is the Bosch relay in fact closing? If not, the original fault, which will no doubt still exist, may have increased in resistance, such that the relay does not now operate properly. Worth checking before stripping things apart.
#88
This is a hot and cold problem (although, it's probably worse when it's hot).
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 07-31-2009 at 07:56 AM. |
#89
Heat often stirs up all sorts of problems. through contraction or expansion taking place.
#90
