Suspension
Does anyone know if coilovers or some other type of suspension is avaible for the SVX?
I wanna go a different route than everyone else... , but the only real thing I can find are Koni Struts... I'm looking for something that will slam the car low, but will also be really really stiff... I suppose adjustability would be a plus too... Does that all make any sense, lol... ?
Jonny Walker |
You could always try going with air. Check out Universal Air, et al for ideas.
How do air rides handle... I want to use the thing (SVX) at a race track, lol... every so often.
Jonny Walker |
Koni struts, Ground Control coilovers = my old setup.
Got a massive drop from those coilovers. Not that I will ever lower any car that much again, but it was doable. Ride height is adjustable, Strut firmness is adjustable. More than firm enough for me, enough to ruin the car's handling at full firm. |
Typically, aftermarket air suspension is stiffer than OEM. There are a number of companies out there making air springs that install over OE struts. You can go from street grater to stock height+ in just a few seconds.
If you really want to be different and have the $$$, try K-Staff's Bilstein/Tein coilovers or Flatt-Racing's Aragosta coilovers.
You could get WRX lowering springs and put 'em on it. We're running H&Rs on our racer now. Rear is still about stock height with all the weight lose but my guess is a stock SVX would be about an inch lower in the rear. Front is another story. You'd have to figure out some sort of way to raise the perch up about 2 inches or go with struts that have a higher bottom shaft. We're about 3 inches lower than stock with about 400lbs less weight up there. By the end of the week it will have WRX front struts on the rear too.
http://www.ridetech.com/productinfo/airstrut.asp
http://www.universalairsuspension.co...27cd1d0ae38ba0
Jonny Walker |
