Old 08-09-2007, 11:01 AM
svx_commuter's Avatar
What holds the crank ina leakdown test?
I got a question
When a leakdown test is done how high is the pressure in the cylinder?
What holds the crank in the TDC position for this test?
Here is a discription of the test
http://www.geocities.com/dsmgrrrl/FA...own.htm#WhyGet
Thanks,
John
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-09-2007, 09:02 PM
Originally Posted by svx_commuter
I got a question
Thanks,
John
(1) Interesting and very pertinent. Surely will be dependent on what is available from a normal shop compressor.
(2) It would appear that the pressure used is not sufficient to move the piston.
It would seem a good test when used to identify a problem, but should be used in conjunction with a standard compression test, which involves non static factors.
Old 08-10-2007, 01:13 AM
ItsPeteReally ItsPeteReally is offline
The higher the better, the leakage is noisier and easier to find. Lots of garages use 100lb psi, but that's just to make the maths easy when doing the percentages
Nothing. If you think about it, when the engine is at top dead centre, you could apply infinite pressure and the piston would not move. In practice, as long as you are within a few degrees of tdc, either way, the rotational force on the crank is very low.
I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely in your thoughts advanced to the state of Science, whatever the matter may be.
Sir William Thomson
