Volvo 244DL won't start, has spark.
My ex-wife's car won't start. At first there was no spark, i checked coil, had spark, replaced dist cap and rotor, and there was spark at the plugs again, but it still wouldn't start. Fuel pump is working fine, i can't seem to figure it out. Can anyone provide some suggestions?
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
The year would help as several different fuel injection systems were used throughout the 240's production. Do you have noid lights? Check to see that the injectors are getting pulsed. Are you sure the timing belt is intact or hasn't skipped? Are you sure the car has fuel in the tank?
It's a 1987 Volvo 244DL. I'm sure the timing belt didn't skip, as i got it running for a very brief time, but i shut it off and it didn't come back on after waiting an hour to retry it, as i htought it might have been fixed.
My Brat acts like that when the coil is about to die. It will have spark, but not enough to make it run properly. Since I've learned this, I've begun to carry an extra coil with me...
undo the lines of the fuel pump before and after. First check to see if the in tank pump is functioning then the primary. Be careful and get a bucket as fuel will spray out. The primary should be fairly loud, you don't notice it when it's not working but when it does you can really hear it. Also check the fuel pump relay, I believe its right above the steering column under the dash on the firewall.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
