Recommend me a tranny cooler
OK, I am finally going to put on an exterior tranny cooler, so can someone recommend one that will cost me less then about $80 and be relatively easy to install, but also effective? Maybe im wishing to much here, but if anyone knows of a specific brand, let me know.
Doesn't matter what you get as long as it's duty rated for a truck.
Got mine from Autozone online. I wouldn't think any one is any more difficult to install than any other.
Sometimes I forget I have more space then most people.
Whatever you get it'll need to fit in front of your radiator somehow.
A core rather than single pipe is typically more effective. Do a search, the wealth of knowledge will enlighten you!
B&M 70268 ATF cooler. Along with the cooler, its a very good idea to install a spin-on ATF filter mount. Best prices for the cooler and filter adapter are at Summit Racing.
Oh yeah and IMHO your an idiot to go to the hassle and expense of putting a cooler on without putting a gauge in so you have a clue what your running at and when you should be changing your fluids.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
True though, the best design depends on your commute. In my setup it has replaced the ac condenser. It's right in front so it get all cool air at speed, but it's harnessed to the radiator so at idle they can share heat and help bring the operating temp to where it needs to be.
