Old 01-29-2007, 01:16 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
haha I know they're old and only getting older... but compare this to the celica forums... people have cars the same age and rarity and don't experience multi-thousand dollar problems annually. I'm afraid to get attached to this car
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 01-29-2007, 01:21 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
I just made some multi thousand dollar fixups and can't wait to get reattached to my car..
Brian
Old 01-29-2007, 01:37 PM
Sov13t's Avatar
Sov13t Sov13t is offline
I'm in the process of doing the same.... a 6spd swap... with the help of Toms
I miss my car very much....
Old 01-29-2007, 01:39 PM
Guess its not so much of an issue if you have it
Old 01-29-2007, 02:08 PM
Sov13t's Avatar
I am a full time student, my SVX's tranny went out on that dreaded night of Friday the 13th of October. I do work 3 days a week the other 2 I am at school till 10pm or so... so it has been a good 3.5 months till everything actually came together, both financially and materialistically (as far as parts and stuff)... I don't know, but if you ask me these cars are unique, so in my opinion they are worth it.
Old 01-29-2007, 02:49 PM
dcarrb dcarrb is offline
Originally Posted by AlcyoneDaze
This site is one of the most depressing car forums I've ever been on... After only two months I wanna get rid of my SVX and kill myself.
I once dubbed this affliction SVX hypochondria, induced by reading too many horror stories here. That's why we need occasional bright, happy, I-love-my SVX threads.
dcb
Old 01-29-2007, 02:52 PM
something like that... I go to school full-time too, work two, maybe three days a week and can wrench on the basics. I think I'm getting the FEAR!
Old 01-29-2007, 06:03 PM
It's Just Eric's Avatar
Missing in action
Hey dude, at 1 grand, you'll have a tough time finding another car that's as nice. If you plan on using it primarily for short winter commutes and incliamate weather only, you might want to invest a little into it to have it last a while. The transmission issue is well worth looking into. Even if you need to replace the tranny altogether, it is a fairly inexpensive repair if you can manage it yourself. With a good tranny the car should resale for over 2 grand, if you happen to be worried about puting money into a worthless car.
Tires would be my second concern. I, of all bloom'in idiots should know about bald tires and how they make your car suck at physics........And especially in bad weather conditions, tires should be a primary necesity
Either way, you might end up putting a bit over 1,000 bucks into it, but what youll have is a good driving car that is comfortable, safe, and stylish.
Nevermind, just read there's a few burnt out bulbs.. sorry to tell you.....but the car is totaled, its worth -$3.47 if you're lucky. You should probly jsut donate it to a charitable cause and use the 3 bucks as a tax write off...that's your best bet
R.I.P Cool Signature.
Old 01-29-2007, 06:05 PM
/semi-obvious sarcasm (fyi2ng)
Old 01-29-2007, 07:47 PM
tmak26b tmak26b is offline
The transmission isnt that bad, but I can feel it is not new. I will change the fluid and see, but I want to fix the oil leaks first. I hate leaks
Old 01-30-2007, 10:04 AM
shotgunslade's Avatar
Tom:
Welcome to the SVX net. I think you will find the SVX just a notch slower than your 350Z. Anyway, hope to see you at a CART event again this year.
Dan
Old 01-30-2007, 06:17 PM
I think the car will blow up before I make it through 3 laps
