Old 01-11-2007, 01:58 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Originally Posted by It's Just Eric
Its rather simple... 5 bolts will do ya (Probly only 2 if it's been removed before)
So true.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 01-11-2007, 02:52 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
Well, it seems I had all 5 screws holding it in place. Now just one or two more questions:
How necessary is the Shift Lock Unit? I'm sure it exists for a reason, but what would the ramifications of its removal be?
I doubt removing the emergency brake will cause any problems, correct? Mine is almost shot as it is, won't even hold the car at full click.
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 01-11-2007, 06:27 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
I THINK YOU WILL WANT TO KEEP BOTH (SHIFT LOCK and THE E-BRAKE. THE EBRAKE IS VERY EASY TO ADJUST, AND YOU REALLY SHOULD DO THAT. On the "driver's side" of the console there is an opening with a cover - a small screwdriver will easily pop it off (but do it carefully). You can see two nuts to loosen - one is the locking nut (on the top). Loosen the locking nut (10 MM wrench) and begin to tighten (clockwise) the bottom nut. This tightens up / adjusts your e-brake. Of course, if you have the console off, this is MUCH easier to do.
Don't know about your location, but a car will NOT pass annual inspection here in Virginia if the e-brake doesn't hold the car when in gear. And as I mentioned, you really should have the e-brake and in good working order.
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 01-11-2007, 07:05 PM
It's Just Eric's Avatar
Missing in action
The shift lock unit is needed if, say, your battery dies and the car is stuck in gear. Pressing the shift lock button will allow you to push the gear selector to neutral to push / tow the car away. *Usefull tidbit* If you car doesnt have the button itself, you need to pop off the decorative cover, unscrew the scrw with the arrow pointing to it (It's long and must be removed all the way) Slide the arrow lookin deal over, and use a screw driver to push into the hole. Dunno why the hell they made it so hard...but w/e
The shift lock computer thingy is small...It can probly be easilly located to somewhere a little more convienent. If you were planning on a custom console, you could make it right up against the shifter and have a nice flat spot over it for mabey like a cup holder or cellphone holding thinger
I think the e-brake is quite necicarry, ya know...just incase. Besides, what's the third passenger doing all the way up there anyway?
R.I.P Cool Signature.
Old 01-11-2007, 07:29 PM
Yes, I was figuring it wouldn't be too hard to relocate that black Shift Lock Unit, I just wanted to know the ramifications of its abscence. I have the button that unlocks the shifter, and use it a lot since the shifter will sometimes 'stick' in park on startup - (does anyone have a fix for this btw?)
As far as the ebrake, I was just toying with the idea of removing it, the state of new jersey will not look too kindly on that come April... I think instead I'll cover it with a black leather shift boot and then custom fabricate grey carpeting/suede to cover all the nasty bits.
I really appreciate the useful help from you guys on this project, and will post pics when its complete
Old 01-12-2007, 04:56 PM
Nick_C's Avatar
Nick_C Nick_C is offline
+1 for the Elantra GT - almost bought an '05 for the wife. Got a Pontiac Vibe instead for a little extra space. But, yeah the interior was really decent.
Nick
Former:
1987.5 XT Turbo GL-10
1988 XT6
1996 SVX LSi AWD
Old 01-17-2007, 08:07 PM
Uh, Yea... vying for supremacy with Mercedes and Lexus I'm sure...
anyway, my console is torn apart, putting a leather shift boot over the ebrake handle to cover up all the nasty bits. I've removed the Shift Lock Unit, its actual function is hazy, since I can select gears with the key in/out of the ignition just fine.
To cover up the seatbelt retractors is the stock ABS plastic topped off with the center console lid (they fit together perfectly!) and the ashtray section is reversed backwards and sits on the floor..... this makes no sense without pics... but it works and looks good.
I've removed over 27+ screws and a lot of useless plastic, metal, springs, and other esoteric bits of plastic and metal whose function I will never know. I'd list the results of my weight removal, but my digital scale is low on batteries.
Old 01-17-2007, 08:19 PM
thats the prototype, cupholder included but not attached
Old 01-20-2007, 06:15 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
*Usefull tidbit* If you car doesnt have the [shift lock] button itself, you need to pop off the decorative cover, unscrew the scrw with the arrow pointing to it (It's long and must be removed all the way) Slide the arrow lookin deal over, and use a screw driver to push into the hole.
Only the earlier-year SVXs had the shift lock button. Later ones require opening the access cover.
Beware: You only need to push the screwdriver into the hole about 1/2" to move the mechanical lever. You should feel a slight springy resistance. If your screwdriver goes any deeper without touching the lever, you need to try again (try a slightly different angle).
If you shove a screwdriver too deep you can tear up the windings on the solenoid that unlocks the shift lever. (Don't ask me how I know this )
... the shifter will sometimes 'stick' in park on startup - (does anyone have a fix for this btw?)
Were you aware you have to press the brake pedal? When you do, do you hear the aforementioned solenoid in the center console "click"? (it only actuates while the shifter is in Park and you press the large thumb-button on the shift lever)
As you can see, the problem could be in any of:
  • Brake pedal switch (if this is bad your brake lights won't work)
  • Wiring/connectors
  • Solenoid
  • Electrical switch activated by button on the shift lever
FYI, there's another solenoid in the steering column that prevents you from removing the key until the shifter is in Park.
David C.
Old 01-20-2007, 09:55 PM
well, I know to depress the brake to remove the car from park... its a slushbox thing, yeah. I only have the problem if the car is parked on an incline and I didnt use the parking brake to hold the car. Anyhow, I tightened the ebrake using the afforementioned method and now it holds fine, it was just loose
