Old 04-07-2006, 10:47 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
That Really Bites!
After swapping my tranny from AT to MT in my Legacy to get it back on the road, it seems to be lacking about 30 or 40 hp. It feels like either the exhaust is partially clogged or timing is retarded. I'll let the photo tell you which.
Old 04-07-2006, 10:50 AM
mbtoloczko's Avatar
sans SVX
Bummer. :-( JB Weld? ;-)
Mychailo
Visit my locker
Old 04-07-2006, 10:54 AM
elninoalex's Avatar
Registered Abuser
The key turned about 80 degrees in the keyway. It looks like about 15 degrees of timing are pulled. It turned the keyway into the Grand Canyon. Fortunately, I've got a spare motor in the parts car from which I pulled the tranny. But now I get to pull the #$%#$% tranny for the fourth time in 2 weeks to get the motor in. I'd take a picture of what my hands look like by now, but it might be too scary for some.
Stephen
Old 04-07-2006, 12:02 PM
I am all too familiar with my hands looking like yours. SOrry to hear it man, and good luck with the swap....again
Old 04-07-2006, 12:09 PM
Man, what a bad deal. I am sorry to hear of the bad luck. Hope it comes out for you this time.
Old 04-07-2006, 03:33 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
That sucks man, hope it all works out for ya after you get it all done
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 04-09-2006, 12:57 PM
elninoalex's Avatar
Registered Abuser
Is the crank from an EJ18 a direct fit replacement for the EJ22E crank? I do have a spare EJ18, which is about as useful as a poopy-flavored lollipop.
Old 04-29-2006, 04:34 PM
elninoalex's Avatar
Registered Abuser
Well, I drilled a 1/4" hole through the cog and put a spring pin in there just like the half shafts. With a new key and crank pulley, it should be good to go. I also swapped on some EJ18 heads to up the CR so it should be fun.
