View Poll Results: How does your 5speed run
Runs great, no problems 10 66.67%
I have grinding in some gears that has developed 3 20.00%
My 5speed runs good other then unexplainable vibrations 2 13.33%
i have ruined a gearbox from abuse. 0 0%
Voters: 15. You may not vote on this poll
Old 02-07-2005, 12:48 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
POLL: 5 SPEED Status
Im talking about 5spd transmission in an SVX. IF your car has synchro grind, runs smoothly, or has broken a transmission let me know!
03 forester box
, 10k miles, 50 or so track runs and unexplainable number of launches. 2nd clutch. Runs smooth as the day i installed it.
~Phil
Old 02-07-2005, 01:00 PM
CigarJohnny's Avatar
While I haven't picked it up yet, Huck's 5-speed has a 5th gear syncro issue and needs to be double-clutched sometimes. I'm not too worried about it though as it is easy and cheap enough to replace the tranny with another one should serious issues arise with it.
Johnny
Old 02-07-2005, 01:34 PM
Johnny
And it has had the Syncro issue ever since I installed it, so it's nothing new....I mean the tranny does have about 185k on it....so a little worn syncro is to be expected....
Old 02-07-2005, 03:20 PM
started off with stock wrx gear box....that grenaded after only a few months..Now im running whith the Ra gears and have no grinding issues when the clutch actually works like its supposed to..However i still have the problem of the car totally stalling when slowing down and still in gear and putting into neutral. Other than the stalling its been fine and very much improved the fun factor of driving the svx. Im running a Sti flywheel/clutch package...Slips like crazy if the rpms arent really really low, however to low and it likes to stall....
Old 02-07-2005, 05:11 PM
svxsubaru1's Avatar
trannie from a 90,or 91 awd legacy. Well i voted for grinding occuring from use, but really it always had some grinding if you shift to fast, but it been getting worse. The trannie either has around 230,000, or about 130,000 miles, so i genraly just double clutch to prevent grinding. I have to admit that that from all of the broken trannie threads at nasioc i thought i was going to break my trannie before now. It only has about 8000 miles on the swap but that was a semi abusive 8000 miles. I never droped the clutch when its been dry out, but i have when its been semi wet and i even got it to spin all 4 coming out dry tight corners a couple of times. One upgrade i would recomend is upgrading to a 20kg STi center diff because i some times have gotten either the front of the rear wheels to start spinning, and hopefulley a sti center diff would fix it.
Old 02-07-2005, 05:14 PM
mbtoloczko's Avatar
sans SVX
About 6k miles on my 02 WRX tranny with STi RA gears. No probs so far, but I haven't really worked it that hard. Less than 10 hard launches. Clutch shudders badly though. Probably my fault. Overheated the flywheel by trying to modulate the clutch while launching for a few 1/4 miles runs.
Mychailo
Visit my locker
Old 02-07-2005, 07:59 PM
Stock 2002 WRX tranny. The gears don't grind except for the bad hydraulic clutch hose that must have swelled and is not allowing the clutch to come up all the way anymore unless I lift it with my foot. As a result I don't get a good release and therefore grinding.
Eventually I'll replace it with an STi braided hose.
About 13 months since the swap was completed.
- 1 trip to Reading
- 1 trip to northern Alberta
- 2 autocross events
I'm not sure how I should vote this one.
Old 02-07-2005, 08:11 PM
Ciscokid
<<< wishes he had a 5 speed so he could vote and give his opinion
Old 02-07-2005, 08:22 PM
thundering02's Avatar
Giong back to the beaters...
Ditto
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 02-07-2005, 08:28 PM
My 5mt is running pretty good. 6k since swap was done. 4k in my possesion. It has whining in 1st and a little in second. I voted for the grinding because it is best described as that. Otherwise runs like a charm. Launched 3 times semi-hard, I am saving all my good stuff for the track. Spec stage 2 kevlar clutch with minimal chatter and Kartboy short shifter and bushing. Shifts like a dream and fast as hell. Looking into a built box to install this summer to handle stage 2 nitrous.
Tom(love those 5speeds)
Old 02-07-2005, 08:44 PM
Subafreak's Avatar
Superbeast
Well I've never had a stalling issue or any other run issue. It did have a starter problem along with the high idle stick on start up. Other than that I blew fifth gear out of my first Turbo Lrgacy tranny (freak thing) and second gear started grinding badly on my second Turbo Leg tranny (after a hard day at the strip) I will let you know how the 6 speed holds up if I ever get my friggen stubs!
Old 02-08-2005, 10:25 AM
That's right, I also had the starter issue. Did you fix your high idle issue? I just put in a switch to fool the ECU I was in neutral.
Old 02-08-2005, 07:42 PM
Subafreak's Avatar
Superbeast
Not really, it would only do it first thing in the morning and so would the starting thing. Ussually all I would have to do is shut it off and restart to make it idle normal but with the starting problem I was lucky to get it started once let alone twice. I'll see how it works out with the 6 speed.
What exactly did you wire up and does it work well?
Old 02-08-2005, 10:35 PM
UT_SVX UT_SVX is offline
livin in AZ
Vibrations
Aproaching 7000 miles and 6 months after swap have a little vibration in first, other than that there are no other problems. I have a 2000 RS transmission,STi short shifter and tranny mount with KB bushings and an Exedy clucth. When I can afford some RA gears I will try to find a WRX fifth gear.
Darren
"Stand up Strong, Feel the Pain! Till the Angels Sing"
Social Distortion
1992 LS-L Pearl White :Optima Red Top, Motorsports Warehouse drop springs and swaybar bushings, Race Concepts slotted and dimpled rotors ,SS brake lines,semi-metalic brake pads, 4.11 5 speed, STi short shifter and tranny mount, Exedy sport clutch, Kartboy shifter bushings, intake silencer removed, ECU Tune Stage 1 v4
Old 02-09-2005, 10:25 AM
mbtoloczko's Avatar
sans SVX
The vibration in 1st gear is probably the drive shaft. I had the same thing. Switched out to a new driveshaft, and the problem was gone.
Mychailo
Visit my locker
