Old 02-13-2002, 03:41 PM
rrrrrrrrrRRRRRRRROOAARR
You know the noise......Rear Wheel Bearing.......Again, on the 5-Speed, Heck, it's only got about 3,000 miles on it! It's the first one I replaced and I don't think I repacked the grease, just used what it came packed in......now I'm wishing I had!
I'd been putting off all the little things I needed to do on the 92, while I've been working on the 94, and I guess she got a little jealous
Well I can't get the new ACT clutch for a little longer
If it's not one thing it's another
Old 02-13-2002, 05:20 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
That sucks. From what I've read in Alldata the grease that the bearing ships in is o.k. but you need to supplement it with Shell whatever grease. What the heck - hang on and I'll get the info - BRB
Beav
Old 02-13-2002, 05:25 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Been there, done that.
Mechanic overtorques bearing. Result: bearing lasted 1000 miles.
Mechainc uses original packing grease mixed with synthetic. Result: bearing lasted 6000 miles.
Mechanic cleans packing grease and puts in synthetic. Result: 15000 miles later, I'm still a happy camper.
YMMV.
VK
Old 02-13-2002, 05:28 PM
Beav's Avatar
Not as old as Randy
It says: Apply sufficient grease to oil seal lip. Specified grease: SHELL 6459N
If specified grease is not available, remove bearing grease and apply Auto Rex A instead.
Do not mix different types of grease.
Personally, I've been replacing Subaru (and many other makes) hub bearings for years and just use normal disc brake wheel bearing grease. I don't recall ever having a comeback on a wheel bearing.
I just replaced the tires on mine today because the ones that were on there sounded horrible. Now that the tires are quiet I'm beginning to hear what may pan out to be the beginning of the end for my RR bearing. If so maybe I'll be able to figure out why so many people are having problems with the replacements.
Beav
Old 02-14-2002, 04:55 AM
Beav
Hey Beav, if you want to tear into mine for practice for yours, I'd let you do it for the experience Just let me know when to bring it up,...he..he...
And vkykam I think I'll take your advise too, and use synthetic grease on the next one.
Now when is my tax return going to get here?
Old 02-14-2002, 10:46 AM
svxter's Avatar
svxter svxter is offline
This account is scheduled to be deleted for inactivity
Send a message via Yahoo to svxter
Beav
The service manager where I take Cleo is of the opinion that one reason there are problems is because the factory spec for the pre-load on the bearing is too tight. He feels that if there were just a couple of thousandths more play to begin with, there would be fewer problems.
bill
Green 95 SVX - Cleo
Green 97 Outback - Maxine
Red F-150 Extended Cab Long Bed - Big Boy
Even the best monkey sometimes drops his banana.
Old 02-14-2002, 03:54 PM
Lowered SVX
has anyone ever had problems with....
front bearings? wait....there are front bearings right? hell maybe it is my tires.....
"Too much fun to drive!"
Old 02-14-2002, 04:23 PM
Beav's Avatar
Not as old as Randy
Re: has anyone ever had problems with....
I can't speak for this group or for just the SVX but usually the front bearings are what do go bad on Subarus. The wheel offset, the vehicle weight and the cornering ability (and thus side-loading) of the SVX are the root causes for wear. Premature wear, especially after replacement, is to what we were referring.
Beav
Old 02-14-2002, 04:26 PM
Beav's Avatar
Not as old as Randy
Oops - sorry
To answer your question, yes there are front bearings also and they do wear out. It just seems that they tend to outlive the rears.
Tire noise can sound a lot like a bad bearing, and can also mask the sound of one. I just need the time to do a little examination of mine.
BEav
