#76
Re: ECUtune Stage 2v7 & Stage 2v7F
Just thought I'd give a mileage update
I drove from SC to NY and back this past week and averaged 26 mpg highway And I flipped 259k on this trip
#77
sweet, thanks
I would have offered you the opportunity to trial the new aggressive stage 1 software by default but I don't think you have a car with a stock or stage 1 ecu anymore. |
#78
Thanks Mike but you're right I am too far from stock to give it a fair shake. My dad parks his stocker for the winter and rarely drives it in the summer or I'd offer him to test it on his.
I think I should add the more amazing thing about getting this kind of mileage is the oxygenated winter gas we are using now should have made it much worse. On top of that alot of this driving was with the torque converter unlocked on the highway. When the temp dropped below about 40 degrees the combinatoin of the PWR radiator ATF cooler and one external cooler kept the ATF just cold enough for it to not stay locked for more than a minute at a time. It's just cool to know that bigger injectors and more aggressive tuning doesn't cause a decrease in gas mileage.
#79
I still haven't installed mine. =(
Been procrastinating. Anyone have two oval connectors they don't need?
#80
oval connector?
#81
He's looking for sr20det style fuel injector plugs
#82
Nikfu, all you have to do is dremel some plastic off the sr20 injectors and you can use the stock svx plugs to keep your svx unhacked.
#83
Waaat.
Tell me moar.
#84
Use a dremel to cut away the extra plastic and to file down some of the tab - this injector is complete and the stock svx wiring plugs right in.
#85
Well I'll be damned. Wonder why I didn't hear of this sooner. I might have to install 2v7 along with all my other projects this/next weekend.
#86
try to use new o-rings...and lots of vaseline..don't dare install them without vaseline.
#87
Well crud, I've gone 26 years without ever purchasing a thingy of vaseline. Now I have to break my running streak?
New o-rings on the way. -- Bah, no they aren't. I got these things so long ago I forgot I had already put new o-rings on them. You guys are tricky, trying to make me get more. :P
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 12-05-2008 at 06:48 PM. |
#88
So I just installed the injectors and MAF, Matt I noticed you have the prongs bent upwards a little. Is that necessary?
One more thing, what is the proper wiring for the MAF? Which wire goes where? The Z32 is white-brown-black-black/white while the OEM is white-black/red-black-red. -- Scratch the MAF thingy, I found a post elsewhere saying they are the same order. Makes shens.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 05-10-2009 at 08:16 PM. |
#89
Damn, if I hadn't tore one of the o-rings injector 3 would not be leaking and I would be cruising on stage 2 right now.
#90
