Quick drive shaft question. Anyone?
Do i need to drain the transmission fluid before i remove the driveshaft? I think i recall it leaking out last time i removed it. thanks.
`92 pearlie 220k Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley '00 GMC Sonoma ZR2. |
You don't need to drain it, but it will leak out when you pull the driveshaft. Just let it drain into a container that will give you an idea of how much you need to add back in.
Of course if it's been more than 10,000 since your last ATF change, then there's no time like the present...
Thanks. I replaced it a few thousand miles ago. i'll just make sure i have a few extra quarts before i get started. thanks again.
