Old 03-08-2021, 12:48 PM
wdb wdb is offline
dances with roads
SVX 5-speed manual on BaT
This one looks familiar, and even mentions a thread on this forum:
https://www.subaru-svx.net/forum/showthread.php?t=50837
https://bringatrailer.com/listing/1994-subaru-svx-12/
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 03-08-2021, 04:04 PM
shotgunslade's Avatar
Re: SVX 5-speed manual on BaT
Yep. It's mine temporarily. Letting it go again. Check out this video from Rich Chen, the interim owner between my 2 periods of ownership
https://www.instagram.com/p/Bik6CU2lqCl/
Old 03-09-2021, 04:59 AM
Why are you selling it after so recently purchasing it back?
Old 03-09-2021, 01:07 PM
Don't drive it that much any more. Have retired from the track and I wanted to get an electric vehicle. I love the car, but it just doesn't fit that well into my life any more. If it does well on BaT, then selling it will not cost me any money.
Old 03-09-2021, 07:17 PM
Good luck seems like the prices have jumped up and there has been more interest in the last few years. So it is probably a good time to sell.
Old 03-15-2021, 03:36 PM
$14,000 Wow not bad!
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 04-02-2021, 06:23 PM
wdb wdb is offline
dances with roads
Prices have jumped up on everything. I guess those work lunches everybody isn’t buying must have been deluxe!
