Old 11-04-2005, 12:28 PM
tman6429
First Time in a 5-Speed SVX...
Yeppers i met a felow SVX owner. I drove his recently 5-speed converted SVX. Very nice, noticeable accelaration. Tonite were going to the local race track to have a little fun. I will post the race video of a Stock SVX with stock tranny VS a 5-speed SVX.....
Old 11-04-2005, 12:40 PM
Earthworm's Avatar
Meow!
So when are you converting?
Old 11-04-2005, 12:58 PM
tman6429
The parts car i have will have a 5-speed on it. Soon as i get a helping hand on doing it. Anyone care to help.....
Old 11-04-2005, 01:18 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Send me a PM when you plan to work on it, I may be able to help some...
Old 11-04-2005, 01:28 PM
tman6429
Do you think we can do it in 1 full day. I can get the 5-speed tranny, and all the neccesary things. 1 More thing, theres no trannn in the car that i am doing the 5 speed swap on. So basically everything is just bolt on.???
BTW you only live an 1 hour away.
Old 11-04-2005, 02:01 PM
Earthworm's Avatar
Meow!
I would reserve at least 2 weekends to do the swap.
The first weekend is used to find out what parts you are missing. The second is for when those parts arrive
Old 11-06-2005, 07:08 PM
Mr.Pwrlite's Avatar
Mr.Pwrlite Mr.Pwrlite is offline
Small world?
tman, sounds like you drove the svx I put together 2 weeks ago. That was the first awd 5sp I drove . fwd is great, but the traction of the full time 100% awd is incredible. Now it's time to convert mine to awd. Anyone in my area have a spare rear diff and axle assembly for an svx?
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
Old 11-07-2005, 09:32 AM
tman6429
Yeah i like it also. But i think he should have upgraded his clutch to a stage 2 or something, the stock legacy clutch isn't gonna handle extra power. Help me with my 5-speed swap and i will find you a rear end.
Old 11-07-2005, 09:00 PM
Mr.Pwrlite's Avatar
The stock clutch is fine for what he's doing, but yes a street/racing clutch would be much better ($ $). Just remember although it seems the 5sp can take a little more beating than the automatic, you can still damage your tranny. A hp clutch assembly will definitely putting more torque to the ground which is good and bad.
I've been running with the same stock Legacy clutch since I first installed my 5sp. Once in a while I experience some slipping during hard acceleration, but I still don't know if I want to upgrade the clutch assembly yet. Anyone wanting to do this swap with their daily driver will have no problem using stock. Now because you race, I would recommend any upgrade you can afford to do.
If you'd like, we can meet somewhere over the weekend and discuss your plans. PM me and let me know. I may be putting my regular door hinges back on for the winter this weekend, so I'll be a little busy but I'll have time.
Old 11-08-2005, 10:13 AM
Earthworm's Avatar
Meow!
No clutch slippage with the stock WRX clutch.
Old 11-08-2005, 04:46 PM
Mr.Pwrlite's Avatar
sounds good, but unfortunately we can't use the WRX clutch with the legacy trans. That's if the splined shaft on the WRX trans is the same as the Impreza. I found out the Legacys shafts are larger in diameter.
