Old 01-03-2003, 11:34 PM
bradr69
help w/ bearings?
I am trying to the driver side rear wheel bearing. I have the whole brake brake/wheel assembly off the car. Does anybody know how to separate the inner wheel hub from the outer wheel hub? you have to take these two apart to replace the bearing. any help would be appreciated. Thanks, Brad
Old 01-03-2003, 11:59 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Yup, I do. You can either trot the assembly down to your local machine shop or garage and toss them $20 or so, or buy the tools to do the job - about $265. Do a search for 'hub tamer' and/or rear bearings and you'll find more info than you thought possible.
Good Luck
