Old 09-06-2010, 06:30 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Powder coated my STI wheels
I couldn't leave the stock silver alone, I had to have them in grey.
Now I have to work a weekend to pay for tires.
Also, I would like opinions on the somewhat heavy powder coat on the
steel inserts. Should I just leave it or have it removed?
The close-up pic shows what I mean.
Thanks
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 09-06-2010, 10:18 PM
Re: Powder coated my STI wheels
One foreseeable problem comes when you tighten down the lug nuts.
After I had my stock ones powdercoated I had to re-torque the wheels four times before everything was well. I torqued them to 80 ft. lbs after installation. I checked them about 50 miles later and they needed torquing again. Seems the finish around the lug nut seats compressed over time.
The other problem comes from the fact that the wheel insert and the wheel itself are one finish. If tightening down the lug nuts cause the finish to compress, that is okay, but if it cracks and separates, the integrity of the finish may be compromised.
Old 09-08-2010, 09:15 AM
Rodolfo Rodolfo is offline
I'd leave it. The wheels look very nice.
Old 09-08-2010, 10:20 AM
I agree, I'd leave it. They look fine and you may open a can of worms if you don't.
Old 09-09-2010, 02:04 AM
Andrew P.'s Avatar
Thanks guys, I appreciate all the input.
There was one thing I was thinking of trying though. I am going to
go down to my local tool store and try to find a countersink to match
the lugnuts. If I do, I was thinking that I may be able to safely remove
the powder coating from the lug seats by hand. (NO DRILLS)
If not, I'll just leave them alone.
77' IHC Scout SSII
Old 09-09-2010, 10:28 PM
Nevin's Avatar
Nevin Nevin is offline
Yeah, I'd leave it too.
If you leave it the worst scenario is that you have to tighten the lug nuts mutiple times to achieve correct torque and it smashes the finish UNDER the nut (which you won't be able to see anyway.)
If you try to remove it the worst scenario is that you remove more than you hoped, and have a chip or two that you can see all the time, and you STILL have to torque it multiple times.
Lookin' good, by the way!
Jesus is the remedy
2015 Expedition EL Ecoboost
