Old 12-27-2009, 02:32 AM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
crazy vibration ENGINE !!!
Hello, why the engine vibrates at the stop and acceleration, whene i'm on "D" and "P" after changing the timing belt, water pump, belt tensioner and the gaskets of the camshaft ? Help me !
Thanks.
Pierre-Olivier
Old 12-27-2009, 06:44 AM
Re: crazy vibration ENGINE !!!
hi if it wasnt there before ,recheck your work ,if its out of time it wont run well
charlie
Old 12-27-2009, 07:11 AM
With the engine at idle, briefly disconnect the fuel injectors one at a time to see which cylinder is not fireing. (If that is the case.)
If one cylinder does not make a differance that coil could be bad.
Old 12-29-2009, 11:12 AM
ShiuludeSVX's Avatar
I had a DL that ran, albeit rough.
Found out I was off by just one tooth, on one side after doing the belt
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
