Old 12-22-2009, 07:30 PM
subaruster's Avatar
subaruster subaruster is offline
Send a message via AIM to subaruster
Re: Vibration under load
Glad to hear...I have the same problem you had. When you took off the old axles, did you see anything obvious that could have caused the vibration?
Originally Posted by rlutz View Post
Got the new axles in and no more vibration! Guess it was a combination of bad ball joints and front axles.
BTW, the "cheapo" axles from Advance Auto ($60 ea vs $414 from Subaru ) looked to be every bit as good a quality part.
Next job is to do the rocker cover gaskets & fuel sending units. It just goes on...
1996 SVX Barcelona Red
2014 Subaru XV Crosstrek Hybird Touring
2015 Nissan Leaf
Old 12-23-2009, 09:45 AM
rlutz rlutz is offline
The right axle had a little wear on the end and a little play in the CV joint. The rubber boot was still intact, so it wasn't something you could really see/feel until the axle was out.
Replacing the axles & ball joints also cured another fairly subtle symptom I was having when cruising downhill at 50-60mph on the freeway. At those speeds, the car is almost coasting, and when the engine would "kick-in" I'd get a little clunk/jerk out of the front end (almost like hitting a very small pothole). With the new axles, that's gone and the drivetrain on the front wheels feels much tighter...
Old 12-23-2009, 07:34 PM
subaruster's Avatar
Update: Problem solved. Thanks rlutz! My front CV axles was the problem. She drives smooth again! I could tell that both axles were loose and tired especially on the inner cv hub.
2015 Nissan Leaf
